Git er done!
01SS - Restored Project underway!
Your going to spray it right ?
From a Google search:
It is the late closing of intake valves that cause "reversion" in high performance engines. Reversion is the word most commonly used to describe the fog of air/fuel ejected from the mouth of the carburetor when the throttle is opened at low rpm. Reversion disappears when the engine rpm becomes high enough that the intake valves close before the piston can push air/fuel mixture back through them.
so.... valve float at low RPM?Originally posted by ktl711 View PostFrom a Google search:
It is the late closing of intake valves that cause "reversion" in high performance engines. Reversion is the word most commonly used to describe the fog of air/fuel ejected from the mouth of the carburetor when the throttle is opened at low rpm. Reversion disappears when the engine rpm becomes high enough that the intake valves close before the piston can push air/fuel mixture back through them.2000 Trans Am l 1967 Firebird
^^^ Exactly....Originally posted by 1BADAIR View Postno.
valve timing, intake runner length, intake velocity and more will cause the intake charge to revert back into the intake instead of the bore
However its not as bad as its "defined". I suspected the intake valve was not closing soon enough, but after further discussions with Shawn this is a relatively common occurence with ITB's primarily due to the runner length and velocity. The dyno header configuration may be contributing as well...
Not sure if the next cam (hehehehe - not confirmed but being discussed) will make any improvements based on Shawn's assesment.sigpic
DoubleOriginally posted by Darren View Post800 isnt enough, spray it and get some manly numbers
Of all people Jim, you know how this process works.....one step forward, six back, etc. On another note, my body shop guy stopped by the other nite to discuss some cosmetic changes in the cowl area (just in case) and on the exteriorOriginally posted by BlackBirdDaddy View Post
Oh yes, believe me I know. I was wondering what you were doing with that cowl because I seen your bodyman a couple of weeks back and he mentioned your cowl rework. It may get serious when you start getting into the windshield!Originally posted by OVRKILL View Post
Oh by the way, your w/s washer bottle looks good!
Originally posted by BlackBirdDaddy View PostI was wondering what you were doing with that cowl because I seen your bodyman a couple of weeks back and he mentioned your cowl rework. It may get serious when you start getting into the windshield!
Looks like I have to move some of this work out of state.......
