Ha! Me either...looks cool in my head though, lol.
Called VSpeed and Maryland Speed today....anyone out there looking for a slightly used, 'modified' Corsa...cheap? I have to learn to stay off the phone....
depends how much, whats modified, and pics??
Still on the car at the minute. Had to cut about an 6-8" section at the front of the I-pipe...can't remember why. An intermediate section to replace it, cut-out, or longer Y-pipe would fix it. Other than that, it only has a few thousand miles on it. Less than 10k? Car has never been in the rain, etc. Will have to grind the spot welds off that secure the pipe sections together. LPE couldn't use clamps like everyone else... .
Not even sure what to ask for it...$400? Hard to put a "firm" number on it until I get it off. Plan on dropping the rear end and take it off at once and disassemble it 'gently'.
FWIW...Premium tips too
You can't call it a street car if you're doing wheelies at every stoplight! seriously though, this build is looking righteous! I can't to see it all come together!
Who did you pick up the s60 from? And if you don't mind sharing how much? Pm me.
Lol....
Back on the fence again between 9" and S60....haven't pulled the trigger yet, but MWC is making a pretty strong case. Problem with the 60 is having to add on components like cross member, torque arm, etc. Once you add it up, the two are in-line with each other. Throw in the bonus of weight factor...9 wins. Might get away with my current drive shaft with the 9 but would have to buy one with the 60. Dammit....
why do you need a crossmember with an S60? unless your using a torque arm that you don't want mounted on the trans (which I'd recommend) its not 100% necessary. I'd just go with whichever is cheaper, neither should ever break.
