*sigh* this car is a dick.
So I was hoping last night I could swap the upper control arms on the front. We had put the bolts in from the outside, so we would have to remove the top of the shock tower to get access. Well I undid all the bolts at the top of the shock tower, but there isn't enough range of motion in the new lower A-arms to give me room to pull the shocks down out of the holes. It's at the bottom its travel, but there is still compression in the spring.
So the best ideas my friend and I could come up with:
1. Loosen the k-member bolts, drop the k member enough to pull out the shocks
2. Use a spring compressor while it's still installed, compress the shock absorber by hand to remove it
Of course, this is going to be an issue as well if I ever replace the shocks for any reason. Any input?
