Ah... bummer...
1996 Camaro Z28 LT1 Project
- February 19th, 2010
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
now we're in business
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Got the intake manifold and throttle body installed today. With any luck, it will be on the road this weekend.
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
so there's this small vacuum line that comes out of the wiring harness toward the back of the engine, near the rear of the intake manifold. Where does that one plug into?
Passenger side of the intake. There should be 2 vacuum ports. One to the fuel pressure regulator and then the other to that one.Originally posted by alone_and_insane View Postso there's this small vacuum line that comes out of the wiring harness toward the back of the engine, near the rear of the intake manifold. Where does that one plug into?2015 Silverado
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Only had about half an hour to work today. Plugged in some plugs and got the valve covers reinstalled, that's about it.
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
For you guys who did the AIR delete, what did you use to plug/cap the spot for the hose on the CAI/stock intake?
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Got just about all of the vacuum hookups and stuff done. I was confused about a bit of it, until I realized that a bunch of it was all part of the emissions system I was deleting. So that's pretty much all put together, and I got the PCM, alternator, and serpentine belt all back in as well. So tomorrow comes the radiator, AC condenser, fans, and intake....and running it
I replaced my intake so I didn't have the AIR port.- Brian Meissen
www.shbox.com is a great source of infosigpic
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
Oh don't worry, I've been on shbox.com a good deal, but I've found a number of discrepancies between what my car looks like and what the pictures on the site look like. Most of those pictures are for 1995 MY, but I have a '96. Some of my vacuum lines were different and I have some big module for the throttle cables on the driver's side that I actually haven't seen on any other LT1 car:
I have yet to see anything about that on shbox.com
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
No idea. All I know is it's big and ugly and has throttle cables connected to it.
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
- 3991
- Peter Schultz
- 1996 Z28
- Livonia/Plymouth
yeah it does...although ABS and TC haven't worked as long as I've owned the car (3 years)
