Build looks good. I would go bigger on the converter tho. By a lot.
Purple People Eater!!
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- 1999 BBM z28 Camaro
- Saginaw Michigan
- New Car Sales Consultant
Yea he knows alot just keeps finding little things to make this thing perfect. I went and checked out the new bigger valves and the port job is looking awesome!!! The new vlaves are so much better!! He went with a bigger manley valves on both sides, and damn they look nice. The pistons are mahle and are so damn light!Originally posted by JoeliusZ28 View PostHe is correct in using a high pressure pump over high volume. Whatever it ends up being i wouldn't sweat it too much, sounds like he knows his stuff.
Thats what i said to but my buddy at the shop said he built everything around the converter. The cam is friendly with a 3000k stallOriginally posted by c0ncEpT View PostBuild looks good. I would go bigger on the converter tho. By a lot.1999 z28 Bright Blue Metallic 1 of 10
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
FWIW
The reason there isn't aftermarket LT1 manifolds is because the GM design is damn near perfect.
It will support pushing cars into the 9s.
There has never been proof of gains from the Edlebrock, I think someone found a loss on it, not my by much but it certainly isn't and improvement at all over the stock one.
Just future reference.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
would have to agree, my buddy Chris's LT1 has been in the 8's with a factory GM intake manifold... You'll be fine with what you have though, what kinda caps did you end up going with? nice build btw, i can't believe i haven't seen it i'm blind as shitOriginally posted by Fox Slaughter View PostFWIW
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
Well the only reason i bought it is cause my stock one was ported by a friend and he made the thickness between the intake ports to thin and my shop guy doesnt want to use it. I also found out today i bought the wrong one the red one doesn't fit LT1 head ports just LT4. So im actualy trying to return it. Should i just buy another stock one or just trade to the lt1 air gap?Originally posted by Fox Slaughter View PostFWIW
I honestly ment to ask today and i forgot but im pretty sure he went with steel 4 bolt splayed capsOriginally posted by dawdaw View Postwould have to agree, my buddy Chris's LT1 has been in the 8's with a factory GM intake manifold... You'll be fine with what you have though, what kinda caps did you end up going with? nice build btw, i can't believe i haven't seen it i'm blind as shit1999 z28 Bright Blue Metallic 1 of 10
Lurker
- March 13th, 2010
- 3476
- TJ
Do you know what brand? I am pretty sure I am going to run Howards Billet mains, mine will be 4 bolt straight though, but I plan on making lots of power.Originally posted by Purple94Z28 View PostWell the only reason i bought it is cause my stock one was ported by a friend and he made the thickness between the intake ports to thin and my shop guy doesnt want to use it. I also found out today i bought the wrong one the red one doesn't fit LT1 head ports just LT4. So im actualy trying to return it. Should i just buy another stock one or just trade to the lt1 air gap?
I would return it and exchange it for a stock one.
What is your horsepower goals? I don't feel like thumbing through the thread to find out.
I know someone with a PC black one laying around for sale
Darren *coughs*Last edited by Fox Slaughter; April 30th, 2013, 09:01 PM.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
No i dont i will ask tomrrow and my goals are 500-550hp and my buddy at the machine shop said ill be good for 2 stages on 300shot nitrous...once the motor is running good and i have the money the car will see a built trans and rear and some slicks and skinny'sOriginally posted by Fox Slaughter View PostDo you know what brand? I am pretty sure I am going to run Howards Billet mains, mine will be 4 bolt straight though, but I plan on making lots of power.
Darren *coughs*
And I want a red one lol or purple.
http://www.ebay.com/itm/PORTED-POWDE...ories&vxp=mtr#1999 z28 Bright Blue Metallic 1 of 10
- Greenville, MI
- Die Maker
I have one on the shelf that I'd let go. I can get the casting number if you'd like, I think they had a few different casts.
I have a LT1 intake on the shelf as well, I can even powder coat it for you
Its already sandblasted too...
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
Thanks for the offer Darren. What are we looking for on price if I have you powder coat and I buy it?
Also for those curious what my caps are they are 4 bolt with outer splayed bolts and they are pioneer1999 z28 Bright Blue Metallic 1 of 10
If I were you I would return the edlebrock one, and get a factory gm intake.. in stock form they actually work quite well, if you have the money a port job that is properly done will help but not a ton. I know a lot of guys running just stock intake and going pretty fast with them... by hogging that intake out you will increase the amount of cfm it will flow which yourmotor will never come close to consuming, but inversely you will kill velocity... stick with a 52mm throttle body to, as crazy as at sounds you will never even come close to moving the amount of cfm thbhat a 58 will flow, a 52 will flow plenty and keep your velocity up. I'm sorry I didn't read all your pages but can you give me a runown on what you plan on doing for a shortblock, cam, pcm, and the rest of the car. Love the color too btw! Don't see many of them floating around any more, I don't I've ever even seen one personally
im still using the factory intake and throttle body. Doesnt seem like there is any restriction.-Joel
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
Darn I already bought a 58mm t/b!1999 z28 Bright Blue Metallic 1 of 10
- Greenville, MI
- Die Maker
If wouldn't go over a twin bore 52mm, your 383 wouldn't even max that out.
aka Purple94Z28
- May 1st, 2009
- 1858
- Nick Kerns
- Saginaw Michigan
well Ws6store charges 15% restocking fee plus shipping on the intake im going to loose $130
