not bad at all! Looks like Larry was the closest!
I really wouldn't be bummed out by it man. Like I said that is a really stingy dyno, and like everyone else said the converter is going to eat up power as well. Should be a very stout running car
That's what I told him.. But not on street tires.....Originally posted by c0ncEpT View PostCar should get down at the track. Should run similar to what Larry's car runs off the gas.sigpic
yeah i took it out for a spirited drive once i got home. having some tranny issues. for one the converter wont stay in lockup and at wot it kicks itself out of gear until u let off. thinking its the valve body. have to tear into that to fix the lockup issue so ill see what else is up
other then that it rips pretty good. a lot more power then before
- - 5.3/4L80e/T7875 - -
- Huron Speed Turbo Kit -
1998 Formula
Congrats! I'm sure the cold air doesn't hurt either!Originally posted by Formula Z View Postyeah i took it out for a spirited drive once i got home. having some tranny issues. for one the converter wont stay in lockup and at wot it kicks itself out of gear until u let off. thinking its the valve body. have to tear into that to fix the lockup issue so ill see what else is up
Can't wait to get my exhaust on so I can start rippin around.-Derek-
As I mentioned on facebook no need to feel down about those numbers its a cam only car. Once the trans is figured out you'll be a very happy camper.Doing less with more
asking around the shop this morning i got a couple possibilities. one being the throttle position sensor and the other the pressure control solenoid. both are pretty easy to test so ill try this first.
edit... im now leaning towards tpsLast edited by Formula Z; April 5th, 2011, 09:40 AM.sigpic
1998 Formula
