aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Hope you win, you have done such a great job on this car.sigpic
Thanks Larry.
My buddy has a Detroit tru trac with newer axles for $200.
I won't have abs. Ill have to get a set of 3 series gears. Worth it?2002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Lowell, MI
- Meat Processor
Very good price!Originally posted by mcalus View PostThanks Larry.
What's the benefits from running one? Will I need a specific install kit? He had it in his 99 A4 Z28. I want to say he spent around $600-700 without the axles? I need to get some more info on it.Originally posted by hoogiesngrinderz View PostVery good price!Last edited by mcalus; October 21st, 2012, 09:44 AM.2002 Z28 Camaro A4
I have been really looking to go to the next step with this car.
Going with:
The true Trac
3.73's
New u joints
Race stars.
Now, for the race stars, I think the polished ones will look better than the black chrome. Should I go with 17's in the front or 15's? I was pretty set on the 17s but the more I see a 15" setup I'm digging them more. It's ~$700 shipped for the 15s and $860 for the 17s &15s.
On a side note, it will be going away for the winter in the next week or so, I wanted to lay some fresh marks so I could think about it when I head into town
You buying?Originally posted by c0ncEpT View PostPolished will look better. I say you do a 5th gen brembo swap and use 17's
I should look into a big brake $wap.
2002 Z28 Camaro A4
I know on LS cars it really isnt to difficult. Just need to drill out the caliper mounting holes and get the inside of the rotors turned.
http://ls1tech.com/forums/suspension...02-camaro.html
17s look sick up front but if your running a 4" rim then look at tire prices they are big $Doing less with more
Post Whore
- August 16th, 2007
- 2881
- Jim
- Traverse City, MI
Personally I'm not a fan of the 17's up front with 15's in the rear. Stick with one wheel diameter front and back, IMO. Polished would look AWESOME on that car.
Curious what it costs. Looks killerOriginally posted by c0ncEpT View PostI know on LS cars it really isnt to difficult. Just need to drill out the caliper mounting holes and get the inside of the rotors turned.
I liked the 17s in the front at first. Maybe it's just the vette I saw them on that I wanted. That is true, a 15" tire is much cheaper.Originally posted by DETROITMUSCLE View Post17s look sick up front but if your running a 4" rim then look at tire prices they are big $
I'm leaning towards themOriginally posted by birdie2000 View PostPersonally I'm not a fan of the 17's up front with 15's in the rear. Stick with one wheel diameter front and back, IMO. Polished would look AWESOME on that car.
I better get them the sooner the better since I'll be getting slammed with ~700 in tires :/
Suggestion on tires?2002 Z28 Camaro A4
Today she went into hibernation. My mice deturant was sleeping on the job!
I'll make a detailed todo list and stick it on the wall. I have a lot more plans for get this winter. As long as work stays busy I will hopefully get a lot done.
2002 Z28 Camaro A4
Just walked around the car and this is my winter to do list so far:
-Fix drivers and passengers bezels and switches
- powdercoat the valve cover bolts
- install new trans pan
- por 15 undercarriage
- adjust exhaust tips and fix leaks
- install trans cooler that has been sitting around
- fix interior rattles (possible? Lol)
- figure out why left rear speaker is inop
- wetland and rub whole car (***** be looking good)
- fix passenger door skin
- paint exterior side maker screws.
Stuff I need to buy (should be roughly around $1700):
- LCA's
- SFC's
- Belstein rear shocks
- new trans fluid after new pan is installed
- trans temp sensor
- 373s & install kit
- rearend fluid and additive
- carpet
- headliner
- speakers (something cheap, better than junk kenwoods I have)
- heat/ac knob for interior
- NON LOCKING GAS CAP so sick of the thing
- drivers and passenger lock caps for interior.
I think all of this is doable. I hope y'all have confidence in me
I'm on the wall about the set of Dragstars and the TrueTrac. It all depends on how busy we are at the shop this winter. It might be a last minute thing.
I'm sure there will be more. Stay tuned an as always opinions are welcome2002 Z28 Camaro A4
