Originally posted by mcalus
View Post
They were the only company I could find that made that part. I bought the shaft and gear from jegs. I can't find the part numbers, but all I did was call them and they looked it up for me when I bought it. They were GM parts, the numbers might also be on www.shbox.comsigpic
Big thanks to Brian (bri2203) for the oil pan!
Going to bump out some dents at work and give her a coat of single stage black.Last edited by mcalus; November 27th, 2011, 01:27 PM.2002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
Got the springs in today.
He ordered 2 different ones because he thought the one I told him was wrong.
The one on the right is the pn Ryan posted.
2002 Z28 Camaro A4
Dad just brought home the cherry picker from a buddy. For free
I just gotta get the 2 "extendable" legs. My buddy should have some thick square tubing. It's an acdelco brand. It looks pretty beefy!!
Posted up on tech about the oil pump drive.
This is a much cheaper route
http://ls1tech.com/forums/lt1-lt4-mo...l#post156839512002 Z28 Camaro A4
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Neither one looks correct. the white spring actually is painted white on the end.Originally posted by mcalus View PostGot the springs in today.
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
ok, it just doesn't show up in the pic.sigpic
white spring ftw. GM made a mistake not putting that in every LT1 from the factory.-Joel
