View Post
Yeah any motor in general can't really be a budget build if you want everything done right although there are things I can cut back on. For instance I also think I'm going to use stock trans until she goes, which I don't expect to be too long.2002 Z28 Camaro A4
1993 Z28 Camaro M6- SOLD
1999 Z28 Camaro M6- SOLD
2008 Ford Fusion SE - DD
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
This would be well spent money since you have a 93. You can tune the engine far better than burning prom's and guessing.Originally posted by ryanwarby01 View PostAt this point I would look into the LTCC coil conversion to ditch the opti. For the money you would spend on a good opti your half way to the conversion kit, plus much better tuning abilitiessigpic
I definatly don't plan on ruling it out just yet. I just rather make it a future mod. As long as I find a good tuner it shouldn't be too much of an issue.Originally posted by Plum Nuts View PostThis would be well spent money since you have a 93. You can tune the engine far better than burning prom's and guessing.2002 Z28 Camaro A4
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Any updates?sigpic
Talked to him today, should have it middle of next week... So he says.Originally posted by Plum Nuts View PostAny updates?
I have been slammed at work and just purchased a new gun
I'm going to stop by Tuesday or Wednesday. I'm hoping it will be no more than $5002002 Z28 Camaro A4
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Maybe you should not have bought gun, you might shoot yourself when you get price. LOLsigpic
Haha, do you really think it will be over $500? The cam, rings and pistons, rod and main bolts are all paid for. The only "parts" he supplied is cam, main and rod bearings, soft plugs and a rear main seal.Originally posted by Plum Nuts View PostMaybe you should not have bought gun, you might shoot yourself when you get price. LOL
As for labor he bored .030 over, cleaned block, assembled shortblock and polished the crank.2002 Z28 Camaro A4
I had similar work done on my block a couple years ago, it cost me $1000 and that was a damn good price.Originally posted by mcalus View PostHaha, do you really think it will be over $500? The cam, rings and pistons, rod and main bolts are all paid for. The only "parts" he supplied is cam, main and rod bearings, soft plugs and a rear main seal.
As for labor he bored .030 over, cleaned block, assembled shortblock and polished the crank.Doing less with more
I just looked at that gun with the 3.8" barrel, but I ended up buying a Springfield 1911. Those XDMs are awesome.Originally posted by mcalus View PostXdm 9 with the stainless slide
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
I love my XD45. I just bought a FNP-45.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
He needs my main caps and rear main seal housing?
I know what the caps are but what is the rear main seal housing? I doubt he got a new seal. Pics? Thanks2002 Z28 Camaro A4
Nevermind. Looked through my parts and found it.
He played dumb with me today asking if he was assembling the shortblock. No idiot I gave you arp rod and main bolts as a donation!
I'm dropping by the main caps and rear main seal housing on my lunch break tomorrow.2002 Z28 Camaro A4
Update on block
Dropped off rear ms housing and main caps. He ordered a gasket kit and said all said and done just shy of $800 buttttt since he knows me and it took so long $600
Good enough for me! He said plan on picking it up Wednesday.
Also he said he had to resize the rods, that arp said so. What's that about?
Woooooooottttt
I'm geeked.
2002 Z28 Camaro A4
