  • I finalllllly got around to doing the tb coolant bypass. Lol should of been one of my first mods!
    Anyone want a ls1 lid conversion. I don't plan on hacking up my oem ss hood for it.
    2002 Z28 Camaro A4
    1993 Z28 Camaro M6- SOLD
    1999 Z28 Camaro M6- SOLD
    2008 Ford Fusion SE - DD
    • You know how many people have told me my car is just an LT and then minutes later got to see my tailights? Or at least had a reaction something to the effect of "wow, i never expected you to hang"
      My car is worth to me what I think it is, no one elses opinion matters.
      • I've heard of the TB coolant bypass, what is it exactly? What does it do, and how is it an improvement?
        Originally posted by JasonH
        • Originally posted by alone_and_insane View Post
          Basically GM thought under extreme conditions the tb would freeze. So they ran coolant in it to warm it. Well warm air is more dense which creates a power loss. Now we are talking g 5-7 hp but for being a "free" mod.
          You just connect the 2 coolant hoses going to the tb together then cap off the tb.
          2002 Z28 Camaro A4
          • Ive driven my car, even in its cammed/modded state in 15 degree weather and it ran just fine. Not needed at all for a summer car.
            • Thinking of hydrodipping my cai as well as my intake elbow carbon fiber. Maybe the valve covers? Too much?
              I have a hydrodipping kit, haven't used it yet.
              Got the new redlinegoods shift boot. I had the thread done in a charcoal just to give it a little touch.
              Some new lighting for the garage. Need to get this up before winter!
              2002 Z28 Camaro A4
              • i say do it!
                • I like the CF idea for your cold air intake and valve covers.
                  I've seen this hydrodipping process done, but didn't know there was a kit available to do that at home.
                  Poking around the web, I see several sources for these. Where did you purchase yours at? And these are coming with the film pre-printed, right? So you have to order it with the pattern you want (obvious I guess, but just checking)?
                  • Originally posted by DynoDave View Post
                    I think I got mine from mydipkit.com ... I can't give any feed back tho since it's been sitting in the box since I bought it.
                    I think I'm going to do my buddy's intake first and see if I like the carbon fiber patter that I got (there were multiple to choose from)
                    Also once you dip it, you will want to put a good quality clear on it. The stuff they give you in a can won't hold up long being in an engine bay or being in the sunlight.
                    2002 Z28 Camaro A4
                    • Could you fellas school me on wheels spacers?
                      I am looking to kick out my rear 17x11s just a tad so they don't rub when I hit bigger bumps.
                      Would these work? Do I need longer studs?
                      http://www.summitracing.com/parts/bs.../applications/
                      2002 Z28 Camaro A4
                      • I finally got the connectors I need for my dash harness/conversion. Big thanks to [MENTION=2227]white97z28[/MENTION]
                        If it doesn't sell by winter (which I expect it not to) I'll be carrying on with the dash conversion and the ttop conversion will be closer to spring so I can take it to work to re spray the roof.
                        2002 Z28 Camaro A4
                        • Every time this thread gets bumped, I think, "Man I hope Michael didn't sell his car."
                          • this car is getting closer and closer to completed work of art. then he wont want to sell... i hope
                            • Lesbhonest
                              2002 Z28 Camaro A4
                              • 2002 Z28 Camaro A4
