Project DZ74
This is a sticky topic.
  • Yeah. I always use Putfile, since it usually has a pretty decent quality. Youtube tends to make bigger files lower quality.
    • OK, here are 2 vids;
      First is DZ74 at idle
      http://videos.mifbody.com/video/a7962ea5-d09b-4e6c-ba62-9ad6017b0b6b.htm
      Second is at 2500 rpm during cam break in
      http://videos.mifbody.com/video/85e24135-c57e-4f8d-8e47-9ad6017ce686.htm
      '73 Z28 388 Stroker, M22 Rockcrusher 4 speed
      WMCC Photographer and owner of Redline Photography
      You are only young once but you can be immature your whole life!!!
      • Sweet!!!
        Sounds wonderful.
        • **** ya!
          • yummy... i love those wheels on the car....
            • Sounds great!
              • sounds great - congrats on all the hard work
                • UPDATE for today ............
                  Ray was here pretty much all day. We got the brake master cylinder mounted along with the new SSBC adjustible proportioning valve. It took a little creative engineering, but we got it done. We bled the system and everyhting turned out well. The Project now has an engine that runs, and brakes that work !!!!! We're getting closer.
                  So, we moved onto the hydraulic clutch, and that's where we hit a snag. This was a hydraulic clutch master and slave cylinder (used) out of a '95 Z28. When we started to bleed this system, we discovered brake fluid running down under the dash near the pedals. The master cylinder was leaking around the rod.
                  Luckily we found this before we had any front end sheet metal installed. It was still a big pain in the neck to remove the master cylinder, but would have been much worse with the fenders and inner fenders on. We'll pick up a new master cylinder and try it again.
                  RIP Doug,You will always be remembered
                  3/3/53 ~ 12/22/10
                  1985 Camaro IROC-Z
                  1974 Camaro Type LT / Z28
                  2002 Trail Blazer LTZ
                  1996 Camaro SS (Sold )
                  www.wmcamaro.org
                  • A VERY BIG DAY FOR DZ74
                    After 12 hours in the garage .....
                    The clutch is all hooked up and we actually got to turn the rear wheels using the motor
                    The rest, the pics can speak for themselves
                    • Gorgeous! Almost all together!
                      • Ray is the man !!!!!! Over 12 hours out in the garage today. Thanks for posting the pics, Ray. We're getting to be a pretty good team.
                        I can't believe we're getting this close. The hood was just sitting on there so we could check alignment (and see how it looks! ). There's still quite a bit to install for the front end: Upper & lower valances, headlight housings and headlights, bumper, several brackets, etc. But, we're closing in on having it "streetable".
                        There's tons of details and little areas to attend to yet, but we're gaining on it.
                        3/3/53 ~ 12/22/10
                        1985 Camaro IROC-Z
                        www.wmcamaro.org
                        • Oh man! Looking great!
                          • Keep up the great work! Looking good and that color is sweet.
                            • I honestly can not wait to see it at the Berger Chevy Show! I'm so excited!
                                Your not the only one. I really wish I lived closer so I could spend more time up there helping.
                                — Thomas Jefferson
