Today was a very historical day in the life of Project DZ74. She started and ran for the first time in 22 years tonight. My buddies, John S. and Ray C. were over tonight and we and we got the old girl fired up.
The engine fired right up after we finished priming the oil one more time, setting TDC and installing the distributor. She ran for about 5 minutes while we set the timing and such. When we started to run up the RPMs to run in the cam, she over heated on us and sprayed coolant all over the place.
We fiddled with the wiring on the electric fans and set a big floor fan in front of the radiator, and fired it up again. This time the tamp stayed steady and we were able to run the cam in for a half hour.
We idled her down, checked the timing again and enjoyed the sound of the L-82 350 breathing through the headers and Pypes stainless steel exhaust system.
I still hardly believe it happened. 8-O
So, that was one BIG step towards getting the Project finished and back on the road by August 22/23.
RIP Doug,You will always be remembered
3/3/53 ~ 12/22/10 Western Michigan Camaro Club - President 2002 Hot Rod Magazine Ltd. Ed. by Berger 1985 Camaro IROC-Z 1974 Camaro Type LT / Z28 2002 Trail Blazer LTZ 2003 Honda VFR 800i Interceptor
IT'S ALIVE !!!!!
And she sounds GREAT I can not believe how easily she fire up!
Thanks go out to Dave Kemp for checking out the engine for us and setting up the heads and valve lash and John Smith for the outstanding experience and troubleshooting tonight.
'73 Z28 388 Stroker, M22 Rockcrusher 4 speed
WMCC Photographer and owner of Redline Photography You are only young once but you can be immature your whole life!!!
I have video shot with my camera but have no way to host it and don't know yet how big the files are. Can I email it to someone to host?
Will be at least tommorow night after work.
What some may not realize is this is NOT a motor we just built.
Doug assembled this engine 22 YEARS AGO but never fired it. It's been sealed and sitting in the garage for more than 2 DECADES.
We had WMCC Dave K go through and check it out. He even used one of those little camera's to see inside the bores. He checked the heads, installed the roller rockers and set the lash. Carb guru Jim Buckmaster in Wisconsin rebuilt and tuned the carb for us.
Then last night WMCC John S. worked his magic and now she lives and breaths again!!!
6 WEEKS TILL BERGER!
Wish I would have been there lastnight with you guys Unfortunately I didn't see the email until about 7pm when I got home from work.....and by that point was to tired to make the trip over.
LOL, tried to call you so you could hear her running but it said "ALL LINES BUSY, TRY AGAIN LATER "
Ray, depending on how large the files are you can either go to http://videos.mifbody.com/ or even putfile.com and host it either place.
