OK, it's "OFFICIAL", we're canceling the work day on Saturday due to unusually cold forecasted temps. :snowman:
Naw, I think you guys should go ahead and work. It will be 67 degrees where I'm working LOL.
To be honest the painter suggested waiting a little while to put trim back on as he said the paint will continue to get much harder over the next couple of weeks.
'73 Z28 388 Stroker, M22 Rockcrusher 4 speed
WMCC Photographer and owner of Redline Photography You are only young once but you can be immature your whole life!!!
Did they bake the car after paint? I don't know what Berger's setup is if they had any type of heat-cure setup they use. If not, I'd definately suggest waiting at least a week before putting the trim on. Nothing is worse than putting trim on and having paint humps around the edge because it was still soft when you put it on. Being cold it will take longer than normal for it to cure.
Wade 2002 Camaro SS T Top Black M6 SLP 345HP 1985 Camaro IROC Z28 T Top Silver 305TPI Auto
STOP POST WHORING SEAN!!!! You're worse than Gary today!!!
Yes, the car was baked. And no, we shouldn't put trim back on the car yet. There is a lot more stuff that needs to be accomplished before putting the trim back on the car. I am very concerned that some of the painted items may get scratched or worse by leaving the on the floor in Dougs garage by people working or just admiring the painted pieces. We should come up with a plan as to where the"finished" parts should be stored (out of harms way) while we are working on the other stuff.
