I just went out and removed the 15mm bolt from the driver side and found all 3 ground wires attached securely, I reattached them and the car fired right up but then it died backing it onto the lift because I didn't 2 foot it. After that we tried to start it and it backfired a couple of times and shot flames out the headers. Any ideas on what may be happening? We didn't seem to have this problem the first time we started the car up a few weeks ago but now we are.
Project Never Fast Enough
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
Im guessing since it sat without a battery the computer has to relearn idle. Now im not sure how long it ran for but my untuned car takes FOREVER to figure its idle and warm starts out. Could just need to learn a little more. Sounds tune related reguardless, not sure what else it could be?
And you just did the rear main right? Wow, that blows. Im going to have some free time next week and have to take my car to phil maybe i can stop by and help for a while if you need it.
EDIT: just thought of something, are you sure its not the oil pressure sending unit leaking, then running down the back cover? Ive heard of it before.1999 Camaro - 6 liters of fury.....
I will check the oil pressure sending unit tomorrow morning but I am 99% sure its not it because you cannot see any rundown at all and thats what was suspected last time when I replaced the rear main. The only thing I have to say about it is that the oil must get on the flexplate because my starter and header on the passenger side have oil spatter on them because of me not having the dust shield on. The oil that leaked out was considerably much less than last time and the oil and coolant leaks only occur when the car is running.Doing less with more
at this point anything is possible, including selling this POS and getting out of this hobby.Doing less with more
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Hang in there Jeff, I can feel your frustration. Both B and I, but take a deep breath man, and tomorrow is another day. I have a hard time thinking that rear seal is leaking.sigpic
You can't afford anything, so shut up. Maybe you need to take a couple days, forget about the car, and start on it again in a few days Jeff. That always seems to kinda clear my head and calm me down.Originally posted by c0ncEpT View PostTrade you straight up for a 99 TA with no mods :]
99 Camaro Z28 A4
Yeah guys it is VERY frustrating at this point, I am honestly considering paying a shop to do it and being done because obviously if it is the rear main seal I don't know how to put it on or am doing it incorrectly. Also Spencer the only other thing back there that could be leaking is the oil pan gasket, which is brand new, and the oil plug in the back of the crank but that was bone dry in there the last time.
Larry I used some red loctite on the flexplate bolts, I am pretty sure.Doing less with more
