I talked to our insurance and they said that since both cars involved are on the same policy, there is nothing they can do.
My Mom says that she will do her best to cover the damage. Hopefully with that money, Christmas, my bday in February, and money I have saved up, I will be able to get the paint work I want.
Awesome man! I see the holes for bolts - do they all come that way or is that a bolt in kit? I want to get bolt in but I don't like that it costs more for the bolt in sets.
Probably a bolt in kit. When I put them in my car I'm going to get a weld in kit and drill holes up front. That way I can bolt and weld them in.
1999 Pontiac Trans Am- LS1 - M6 - ITSSLOW - 12.998@109.59 - SOLD
1994 Chevrolet Camaro - 3.4L - M5 - ITSSLWR - 16.558@85.38 2003 Chevrolet Blazer
I'd imagine you could just buy a weld in kit and drill your own holes to save money but I bet they would be kinda hard to drill. Other than that are the tubular sfc's any stronger or weaker than the ones made with rectangular tubing?
Yeah, this is the bolt in kit. They way I look at it is that the bolt in and weld in kits are essentially the same, except for the bolt hardware that comes with the bolt in kit, so it will be a little more expensive. You don't have to take a bolt in kit somewhere and pay to have it welded in.
You still have to support the car completely so all tires are off the ground when bolting it in though right? I've heard you have to get it up on a lift so the frame sits evenly, at least for the weld-in kits.
No, you need to have the car up in the air, with all the tires LOADED. IE, front end on ramps, rear jack stands under the AXLE, that way it is just like if it was sitting on the tires.
no, you need to have the car up in the air, with all the tires loaded. Ie, front end on ramps, rear jack stands under the axle, that way it is just like if it was sitting on the tires.
Definitely. If I could find someone that had a shop with a drive on hoist that was near by, say around between 23 and 24 & Schoenher that would let me put these on and do my motor mounts, I would be really appreciative.
