So, I found that MSR sells the Enkeis that I want, just not as expensive, and are made in the US, so I'll probably go with the black ones that have the chrome lip, when I get the dough...
I got my 130mm bolts for the alternator and 110mm bolts for the two bottom middle intake manifold holes.
I broke my antenna on Woodward last night - so it appears I'll be needing a new one, I'm gonna look into possibly getting a 2005 antenna bracket cause then I shouldn't need to re-do Tim's antenna I bought, since the 07 has a weird thread size (they increased it). So, for now, I have no antenna, but I don't usually use the radio anyways...
Oh, and I used an app on my buddy's iPod touch, and ran about a 7.8 second 0-60 time with two people in the car. Slow, but it's about what I should be running...
All right - the swap is going down tomorrow, or that's how I plan it - anyone is welcome to come over during the day to help out or just hang out!
Got a few parts a week or two ago...
LSJ Brake Booster hose:
LSJ 1-Bar MAP:
Coolant Reservoir (was like $8 from Murray's - will do for now)
Pulled off the endplate today - just to check, and it looks pretty good:
Engine bay without the top cover:
Stock Downpipe:
Downpipe with O2 Bung welded in:
Supercharger and TB being taped up for paint:
Taped up and ready to go:
Bought Dexcool, 50/50 (for H/E circuit), the coolant reservoir and Duplicolor black engine paint yesterday; and clear Duplicolor engine paint, 3/4" tee, hose clamps, 6' of Heater hose and masking tape today.
Also got in my upper radiator hose, heat exchanger pump insulator, 8-pin throttle body pigtail, heat exchanger pump pigtail and the intake manifold gasket from GM today - as well as 6 more feet of 3/4" heater hose and Water Wetter from Summit.
