My new 1988 T/A
  • A few more pieces of metal today. Starting to fall behind a little. Going to have to get a lot done this coming week.
    So how long did MOPAR continue to stamp out replacement deck lids for 75-77 Cordobas? At least through late November 1983 it would appear.
    • I'm sure all the heat probably didn't help motivate you to be outside.
      • I don't love being outside in the heat, no. But mostly it's finding the time. And the space. The back garage is just about full, with the only remaining large space being around the Trans Am. And everything that is left to do is a large part. So I just don't know where I'm going to put stuff. I think the yard equipment is going to get the boot (some of it already has). If that's not enough, I may have to put some things in the rental storage unit with the Chrysler, which I have been trying very hard NOT to do. And I will NOT put large sheet metal panels around the Trans Am, where they could fall over and damage the car.
        • You know, it's funny - stuff doesn't seem to fit as easily when you put it back.
          • A couple of more panels done this afternoon.
            • A few more panels knocked out. I keep telling myself the front garage is almost empty, yet I keep finding more stuff!
              I have 4 of these for the new shop. This is the only one that was charred. I'll have to have it blasted again, and start over.
              My Charger's original hood.
              Cleaning up nicely (right side). A '71 RR 383/727/8.75 prop that came with the 8.75 axle I bought. Both headed into the Chrysler.
              • The last few items were hurriedly moved out, and the demolition work began on Tuesday.
                A few errors occurred here. They were not supposed to demo the drywall on the walls. By the time I saw it, it was too late. They also were not supposed to remove the 16' of workbenches, nor the 6-7' of desktop area. So those will have to be reconstructed somehow. The upside is the exterior walls (not shared with the house) were not insulated. I'm going to pay them to do that while they are in there. Also getting a little electrical work done, and having the exterior entry door replaced.
                I now have a new pile of things to go through again...the old cabinets, a few missed contents, and some other odds and ends.
                More curious smoke patterns, this time from a sheet of peg board sitting 1.5" off the wall. These were 4x8 sheets laid on their side, so 4' up from the workbench surface. Curious how the smoke pushed it's way through the first 5-10 rows of holes, then swept downward.
                • Well...a bit too much demo...but having those walls insulated is going to be huge.
                  The smoke pattern behind the pegboard is absolutely nuts. It's really insane to think just how the physics of it all works, in that the movement of smoke is very hard to predict.
