  • Superman09
    replied
    It could go 11's or 9's. Way to many variables.
    Have Jonny hook you up with a turbo cam. They guy that does them for him is VERY good.
    What he said!
    Leave a comment:
  • c0ncEpT
    replied
    Originally posted by Formula Z View Post
    I was hoping to do 12 or 13 lbs. Any idea what kind of hp or 1/4 this will make
    Leave a comment:
  • Nocooler
    replied
    I wouldn't tear it down and open the ring gaps. What happens if you break a ring? Then your stuck honing/re-ringing and then it'll snowball from there.
    5.3's are so cheap if it comes apart - throw another in it.
    Leave a comment:
  • Formula Z
    replied
    Thanks dave. Think i made the other guys mad lol.
    Leave a comment:
  • 1999Black_Z28
    replied
    And one more question, can i still have a "boost" cam that has a lil lump to it? I know, silly question, but i love the way a lumpy cam sounds
    yes, many lumpy turbo cams available
    Leave a comment:
  • Formula Z
    replied
    Leave a comment:
  • Formula Z
    replied
    I probably wont have any real technical questions until i get the kit and actually start putting it together
    Sorry guys but i do truly appreciate the input
    Leave a comment:
  • Formula Z
    replied
    Leave a comment:
  • DETROITMUSCLE
    replied
    tons of variables but I don't see why you can't make 650+ conservatively.
    Leave a comment:
  • Formula Z
    replied
    And yes i need some kind of reliability
    Leave a comment:
  • Formula Z
    replied
    I was hoping to do 12 or 13 lbs. Any idea what kind of hp or 1/4 this will make. Im sure 12 will be plenty for the street. Im not putting a cage in so racing will be minimal
    Leave a comment:
  • c0ncEpT
    replied
    Originally posted by kammi10 View Post
    i wouldnt worry about it mike.. maybe if oyu were planning on 18lbs.. but you should be fine on anything less then 12.. which i wouldnt suggest going over that on a stock bottom end anyway
    ^ This does make a lot of sense. If your not trying to set the world on fire with stock parts I wouldn't mess with it.
    Leave a comment:
  • kammi10
    replied
    how much power do you want to make? I have seen several guys not worry about it, 90% of it is all tuning and what your tuner is comfortable with making on stock stuff.
    Leave a comment:
  • c0ncEpT
    replied
    I would. You get a good amount of heat in those cylinders and the rings will butt and take out a ringland.
    Cheap insurance if your going to have the motor apart. I would resize the rods for ARP rod bolts also.
    Leave a comment:
  • DETROITMUSCLE
    replied
    So should i open the top ring gap up like everyone is doing?
    Leave a comment:
