Originally posted by Phantom383
View Post
anyone have lpp headers on lt1
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
There are 3 bolts on each side of K frame 2 are in a thicker section and the rear is in a lower section. I believe the part in your pic is the rear section, but its hard to tell from picture.sigpic
We can do it this weekend.Originally posted by Plum Nuts View PostYep after reading this I think I'm going to try the headers on b's engine, we put new motor mounts on his. Plus before I hack the k frame I would be inclinde to put a half to 3/4" inch block under motor mounts before hacking k frame. I don't think Raising engine would cause clearence problems.- Brian Meissen
You might wanna call and tell Kyle that since I believe that he is currently cutting into your Kmember, lol. At least, thats what it sounded like from his last post.Originally posted by mikek18 View Postim up for trying new motor mounts if it would help.
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
O.k. new problem!!!!
That pipe is resting against the frame of the car
There are 2 screws holding the header in right now but it has to come out again.
I have quite the clearance hole in the K-member right now but I'm still hitting it and I don't want to take more out
I have the motor lowered down a bit but the mount hole isn't even lined up yet and I know it will fall at least a 1/4 inch yet so that's not good either.
Mike is out of town right now so I'm at a stand still
Mike you said:
I don't even know if that will do anything for this.I'm up for trying new motor mounts if it would help.
The guy that made the LPP's said that he made the primary's come out further for better plug & bolt clearance but I think that is where he went wrong.
B, any luck test fitting yours yet??
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Here is the LS1tech thread if any one want to read it, 80 some pages
I start ya off on p. 23
http://ls1tech.com/forums/lt1-lt4-modifications/862878-lpp-polished-stainless-lt1-headers-y-23.html
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Sorry man but it's not going to happen.
The motor is being supported by the jack right now.
This just isn't going to happen, I'm sorry.
Will be doing the test fit tomorrow - but with my engine out of the car I won't have nearly as much stuff in the way as Mike's.- Brian Meissen
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
That may not be a good thing but at least you will know if your K-Member is o.k.
I helped derek install his. His DID hit the K-member but it was a very unecessary metal lip that was easy to buzz off. I would not call it "hacking the car up" at all... thats just being rediculous.
If you have to do more than a little grinding, somethings wrong IMO. Derek's headers fit great, better than my pacesetters. I would swap mine out for LPPs in a heartbeat after doing his... but after seeing this thread it seems they have some issues making a consistent product.-Joel
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Where his LSX or LTX ?
From what I have read the LS guys don't really have issues it's the LT guys that have them if they do.
And by joe we do
I posted on LS1TECH also.
Need to get to the bottom of this fast!
LTX.
Seriously, his fit great. I had a much harder time fitting my pacesetters. After i buzzed that little edge off they slid right in.-Joel
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
Well we have an actual hole to where you can see the a-arm and I still would have to take more off, about a 1/2 inch just so it will have clearance.
I'm starting to worry about the structure here
I think I'm going to have to have a piece welded in??
wow. I only took off maybe a half inch (probably 2" wide) and the seam was still integrit when i was done.
Are you sure you arent overlooking something? Is the engine tilted at all?-Joel
