the guy who's picture i borrowed has zero problems with clunking or vibrations. The key is to have adequate hangers and obviously clearance.
Hmm........
my borla sits right on the damn Panhand bar or whatever its called, No noises but it annoys me and there's really no way to move it upOriginally posted by JoeliusZ28 View Postthe guy who's picture i borrowed has zero problems with clunking or vibrations. The key is to have adequate hangers and obviously clearance.
sean oughta like this pic
Must be a truck or one of them 4 wheel drive f-bodies.Originally posted by JoeliusZ28 View Postsean oughta like this pic
1987 Camaro IROC-Z Pearl White & Black w/ Red Pearl, 355 TPI, A4, 3:42, AirRide,"GOMARO"2017 Silverado Double Cab Z71 Pepperdust Metallic, 5.3, A6, 3:42, "SASYZ71"WMCC Website www.wmcamaro.org
are willing to work and give to those who would not." — Thomas Jefferson
you would think, but I was actually surprised how much room is under my car.
Unfortunately i can only give you the guys sig... but its not sitting very high at all (sig pic taken before he put the duals on)
here's another angle. It does look like he may have used a hammer to get an inch or two of clearance, but i cant tell for sure.
no thanks, id rather have a B-A exhaust. happy with my ride height anyway...Until I put 19s on it, but that will be no time soon.-Joel
I noticed that the cross-member below the trans mount is removed. Does this cause any problems or do your sub frame connectors take up the slack?sigpic
um where do you see that? You can remove the tunnel brace, but you definitely cannot remove the transmission cross member. That isnt in the way of anything, my current y-pipe wraps around that and then merges behind it.
Factory tunnel brace is worthless anyway.-Joel
Yeah, I was talking about the tunnel brace -- I just didn't know what to call it. Do you have to replace it with anything when you take it off? I'm trying to figure out what I'm going to do for my setup.sigpic
Ive seen several cars running around without them, i dont think it is a crucial item to have.-Joel
