Cars dead! info provided
  • Cars dead! info provided
    IAC was reading 155 at idle, when it would idle. MAP sensor is reading 3-4 lbs vacuum(or whatever it reads). Car thinks it is at full throttle at idle and is dumping fuel into the intake.. The IAC came down to 30 at idle, when it would idle, Map readings were all over the place.. MAP sensor gone bad?
    TPS maybe?
    http://www.tcevolution.com
      Sorry to hear that Larry
      I now the Feeling cause mines done for awhile also.
      Craig
      Semi Retired Street Racer
      GONE BUT NOT FORGOTEN
      NBM `98 Formula M6 HdTp
      1 of 1 Build Date 3/12/98
      - Smokey Yunick
        I would vote TPS, but i'm a novice when it comes to these electrical gremlins. So i'll just say good luck tackling the challenge!
        Originally Posted by 1BADAIR
          He never said his tps reading were bad. I would start with a map sensor, after you check the connections. If thats not it then you probaly got more expensive problems.
          Sold!
          www.fquick.com/lozanoa11
          94 Grand Cherokee (sold)
          95 Accord(for sale)
          99 Outback (snow destroyer)
            The MAP should be reading way more vacuum at idle.
            I think you have a bad MAP.
              Yeah, I am going to have it flatbedded home and change out the MAP sensor(eventually).. When I left the shop it wouldn't even start anymore.. turn it over and just a quick sputter. Probably done for the year.. Just don't have the time to work on it anytime soon..
                man our cars are dropping like flys lately.... i thought only mustangs were supposed to die lol
                my trans went poop today lol
                  car probly wont start due to plugs being fould out, change plugs and check tps, i know it dont show but if it sticks it will throw massive fuel in the car witch floods the system.... also to save a headach you may already know but change oil, to much fuel will start to dump in the oil and we dont need that.
                    Bad MAP gets my vote
                    good luck
                    hahaha i just need mine to hold together till saturday night then it can be down for a year
                      ill have mine running tonight if it kills me.
                        If you don't want to flatbed it larry then hold the gas down all the way when you go to start it, this put the engine in a "clear flood" mode and it won't fire the injectors and it should allow the car to start. Then try replacing the MAP sensor in the parking lot, I have done it before and see if it helps.
                          Sorry to hear Larry. I think you and Brian need to get together and tip a few back.
                          RED
                            are there any codes?
                            had you just sprayed it?
                            change the plugs. a miss will drive the map crazy
                              Map sensor is going to read all over because its running like shit. It sounds ignition related to me.. Like Larry said.. pull a plug see what you got. Dont go replacing sensors if your unsure if its bad
