Originally posted by DETROITMUSCLE
View Post
dyno dilemma lol
I've heard that helps seat the rings. I've head idling isn't good though. Like Jeff said everyone is different so listen to your engine builder to cover your ass.2015 Silverado
Is this the hill on Baldwin by chance? lolOriginally posted by 1BADAIR View Posti live between 2 decent hills. go up the hill in 4-5th gear. go down in like 2-3rd. load then high vacuum. do that a few times then let her rip. my 383 never seated back in the day cause APE told me no more than 1/2 throttle and 4000rpm
to seat the rings you want to keep a load on the engine. Vary your RPMs, give it some heavier throttle but dont rev it to the moon. Dont "cruise" the car. slow down and speed up repeatedly. When i break in a new piston on my dirt bike i drive it around the yard fighting the brakes on the first heat cycle... my bikes have always performed well after this
Like everyone said the gears need heat cycles.
As far as the rings - I'm a break it in like you drive it. Do a couple part throttle pulls and let off letting the engine slow the car down, it'll smoke for a few pulls, once it stops the rings are seated and I let it eat it.
I think my T-type engine had 30 miles on it before it hit the track, drove it straight there
Ran some mid 11's and drove it home. It had a bad meth problem and liked 25psi+
Honestly - follow what your builder recommended, he's the one that will have to fix it if it breaks.Last edited by Nocooler; March 24th, 2011, 07:57 PM.2000 Formula
fixed slow junk
thanks for the advice. that t type sounds pretty nice. jeremy you are going to have to come hang out at stanton with a bunch of us once everyone is up and running. you doing the meet and greet with us this year?sigpic
- - 5.3/4L80e/T7875 - -
- Huron Speed Turbo Kit -
1998 Formula
I haven't thought about the meet and greet.......might be a possibility. Also depends if my car is back together.....I'm starting to pull it apart - it's going slow.
Typically I'm at the track most Wednesdays - last year was the exception due my accident. Hopefully I'll be able to make it out alot this year.2000 Formula
fixed slow junk
Heads and camOriginally posted by Formula Z View Postwhat are you doing to your car, and what accident?
I was burnt significantly last summer in a brush fire accident. I've made almost a full recovery physically - just working on the post traumatic stress and the scarring right now.2000 Formula
fixed slow junk
Thanks - I think I have the swap under control. I'm not looking forward to pulling the balancer, and the radiator is being a pita right now. I'm debating if I'm going to stick with the maf or convert it to speed density as well.Originally posted by Formula Z View Postoh man sorry to hear it. good luck on the recovery. need any help with the h/c project let us know2000 Formula
fixed slow junk
