dyno dilemma lol
    I wouldn't fret too much over the oil considering its a roller valvetrain
    2015 Silverado
      yeah thats kinda what im getting while researching it. ill just use the rotella t and additive and change a couple times after so many miles
        TJ should be able to get you a base tune, I would not run the car without one for any extended period of time. Once he has that on drive it around and get the car completely up to temp. I personally beat on my car to break it in, Phil retuned it with a fresh motor and I had no problems with that just used non-synthetic oil and did a couple low mileage oil changes. Now I'm back to synthetic. Don't take it from us all though listen to everyone else and talk with the builder and the tuner and see what they recommend.
          yeah ill contact tj this morning and see what he says. also need to call the builder to make sure we are still on course for me to pick the shortblock up friday. thanks jeff
            dilemma diverted!
            talked to tj and he will put a base tune on my pcm for $50 so i can heat cycle the gears. now just to find time to get it out to him this week between 8 and 5
              Originally posted by Formula Z View Post
              dilemma diverted!
              Wow...That kinda sucks....he's charging you $50 for something he would do anyways. I understand the man has to be paid, but that seems a bit much.
                agreed but usually when a tuner does that they just deduct that 50 bucks out of the total cost for the tune
                  yeah he mentioned that it would be deducted and sorry i forgot to add that in my post. so with the base tune am i allowed to beat on it some to get the rings seated? guess ill have to ask tj about that while im there
                    no do not beat on it.. its just a base tune basically for idle and low throttle just so u can drive it. i would not recommend beating the shit out of it.. if you just want to heat cycle the gears just go drive it for a good 10 miles or so and it should be fine.. and then park it and wait til u have to bring it in for the tune
                      thanks sean! so one 10 mile ride will do? that wont mess with the ring seating much? and i wont beat on it. im trailering it to the dyno so it will be the only time its driven. i also forgot to mention that they are american axle gears which are what gm uses correct? and with lucas synthetic gear oil. i just wanna do this right the first time. the car has been down way to long. and im also sorry for all the stupid ass questions. this is my first time doing something like this.
                        you should be fine.. when i put the gears in my 10 bolt i never even heat cycled them.. just went out and drove the car and beat the snot out of it.. they were still quiet as a mouse when i sold the rear end..
                        the gears in my 9 inch never got heat cycled either.. they are still quiet too.. i dont think u have much to worry about
                          Ah, okay...that makes sense.
                          You will be fine with the rings....what kills the rings is firing up a new motor and letting it idle and only doing light load while driving. When you drive the car....just avoid hammering to the point where it goes into open loop. As long as it stays in closed loop the tune should be close enough for it to find 14.7:1. Do you have a wideband?
                            Haha...you never put enough miles on it for it to be an issue. By heat cycling the gears your are ensuring they last a good many years. Has nothing to do with noise.
                              no wideband
                                Just drive it around normal. Vary the RPM a bit. AKA don't just jump on the freeway and set cruise at 70.
                                Some 50-75% partial throttle runs are good for it. Just avoid WOT.
