Did you have vats deleted in your tune? You had the pcm tuned right?
5.3 wont turn over Help!
Enthusiast- January 1st, 2009
- 342
- Chris
- 1987,Chevy,Camaro(IROC)
- Jenison, Mi
- Gentex production maintenance
The pcm has been tuned. I built it.Air Force/Afghanistan veteran
1987 Iroc camaro Supercharged 5.3
2012 Toyota tacoma
- 342
- Chris
- Jenison, Mi
My buddy double check the tune and everything is right. My injectors aren't firing for some reasonAir Force/Afghanistan veteran
2012 Toyota tacoma
- 342
- Chris
- Jenison, Mi
Ok still not starting. Any ideas?Air Force/Afghanistan veteran
2012 Toyota tacoma
- Greenville, MI
- Die Maker
Getting power to the injectors? One wire should have 12v constant and the other is the trigger wire from the ECM (injectors are fired by ECM grounding via a injector driver)
Check INJ1 and INJ2 fuses if your harness was properly converted.
- 342
- Chris
- Jenison, Mi
I have 12v to every injector. I also have a constant 12v to the Pcm. I did continuity checks of the harness connectors to the pcm. Everything check out good. I have spark which I check with a spark light. I have fuel pressure. Only thing I can think is I missed wire something up on the pcm when i built the harness or missed something on the iron harness. I have to double check to make sure the 87 harness doesn't have vats. From what I am told is GM didn't start vats until 88. I am at a lose right now.Air Force/Afghanistan veteran
2012 Toyota tacoma
- 342
- Chris
- Jenison, Mi
I can double check with a test light. It's a 411 and a harness out of a 2000 Silverado.Air Force/Afghanistan veteran
2012 Toyota tacoma
- 342
- Chris
- Jenison, Mi
I have a iac low voltage code. I don't think this will affect if it starts or not. Anyone have any input on that?Air Force/Afghanistan veteran
2012 Toyota tacoma
- 342
- Chris
- Jenison, Mi
Got it. She is alive. I had my feed and return Lines swapped on my regulator.Air Force/Afghanistan veteran
2012 Toyota tacoma
he was checking 12v inputs....Originally posted by ruckusz28 View PostNever use a test light on modern vehicles. A multi metet is a much bettet choice. The light draws enough amperage to deploy restraints or fry a pcm. A guy at the old shop had to eat a huge damage claim when he toasted the pcm of a charger from using a light.
