5.3 wont turn over Help!
  • 5.3 wont turn over Help!
    So I got everything connector last night. I was ready to finally start the 5.3. I turned the key and got nothing. I started checking everything. The battery is good. The start is good and I had power there. The fuel pump turns on. The radio, lights, and gauges work. Everything time I turned the key the radio would turn off. I then double checked the battery. The battery was still good. The starter is grounded. The battery is grounded. I feel like I am missing something important but I am not sure what is it. Any help would be fantastic! Took 3 years to get to this point and I fell on my face. lol. Thanks
    Air Force/Afghanistan veteran
    1987 Iroc camaro Supercharged 5.3
    2012 Toyota tacoma
    put it in park
      lol I am pretty positive it's in park. I did check it but park position is facing the rear on the tranny?
      2012 Toyota tacoma
        I looked it up. It has to be all the way forward. Now I need to go double check. I hope that's it but I doubt it.
        2012 Toyota tacoma
          what trans. what neutral safety switch
            fbody 4l60e
            2012 Toyota tacoma
              how is everything wired. stock f body switch is in the shifter
                Did you properly bypass the pass lock system? Sounds like it's not seeing the correct values and is offering you a no start.
                  What do you mean by pass lock system?
                  2012 Toyota tacoma
                    I am in the process of trying to see where this goes.
                    2012 Toyota tacoma
                      The chip in the key. But it should still crank
                        Not necessarily. I've done remote starts with all generation passlock and each behaved differently. If memory serves correct passlock 1 will crank and no start. Passlock 2 will not crank. Passlock 3 will start, run, and shut down after 3 seconds.
                          http://vats.likeabigdog.com/
                            My buddy programs and he turned vats off. So that's not it
                            2012 Toyota tacoma
                              try jumping the starter enable relay
