Its not all that much loader open Y-pipe. I mean it is but it sounds like poop if you don't have a cam. If your looking for shear noise than your gonna be revving it to the limiter all day tho
<Project> 2000 Trans Am
wow fred your going to have a show car..
99 Buick Regal GS- New DD
SOLD-1967 Buick Skylark
What have you been using with the scotch brite pads to clean everything up? I'm debating doing some work underneath my car late this winter/spring, including a lot of painting to factory black pieces. My entire exhaust is stainless, but my pipes aren't as tarshished as yours were. I'd like to get all my stainless back to close to a mirror finish. I've seen some people have success with oven cleaner and scotch brite pads, any input?-Derek-
yeah... thanks for waking me up.....Originally posted by Lucky SOB View PostI can't wait to start it up tomorrow
Didn't want to wake up the neighbors tonight...-Will-
2001 Monte Carlo SS 3.8L
Mods: i wash it to make it go faster!
if the shoutbox counted towards your posts, i would be a top poster...
"That ain't no '10!"
I've just been using it on its own. I've seen the oven cleaner method and that seems to work pretty well also. The scotch brite pads leave the stainless with a brushed look - definitely not mirrored like my tips (see below). To get the mirror finish you have to polish them, no way around it. I may end up polishing mine, I'm undecided right now. What I did just discover is, my Y-pipe is not stainless, but painted aluminized steel. I'll probably scuff it up and hit it with a fresh coat of high heat silver paint.Originally posted by Derek View PostWhat have you been using with the scotch brite pads to clean everything up? I'm debating doing some work underneath my car late this winter/spring, including a lot of painting to factory black pieces. My entire exhaust is stainless, but my pipes aren't as tarshished as yours were. I'd like to get all my stainless back to close to a mirror finish. I've seen some people have success with oven cleaner and scotch brite pads, any input?
On another note... who has pulled a 10-bolt and how big of a PITA is it to do? Doesn't look to be that bad honestly and I'd love to take a wire brush and then some POR-15 to mine. While I had it out I'd probably throw a TA girdle on it and maybe a panhard bar and LCAs if I can find the right deal. Probably just single end adjustable. This is a straight line car, not worried about cornering. Any recommendations are welcome.
Something like this... I'll wait for a sale though...
http://www.umiperformance.com/catalo...roducts_id=346Last edited by Lucky SOB; December 19th, 2010, 01:46 PM.2000 Trans Am l 1967 Firebird
its not hard at all to take it out. If you wanna do it over xmas break I can come help you. you will have to disconnect your brake lines tho, causing you to have to bleed your brakes.Originally posted by Lucky SOB View PostI've just been using it on its own. I've seen the oven cleaner method and that seems to work pretty well also. The scotch brite pads leave the stainless with a brushed look - definitely not mirrored like my tips (see below). To get the mirror finish you have to polish them, no way around it. I may end up polishing mine, I'm undecided right now. What I did just discover is, my Y-pipe is not stainless, but painted aluminized steel. I'll probably scuff it up and hit it with a fresh coat of high heat silver paint.
It wouldnt be a bad idea to take it out, clean it up, paint it and change out the fluid in it.
That's what I was thinking... alright we'll be in touchOriginally posted by ThreeHonks View Postits not hard at all to take it out. If you wanna do it over xmas break I can come help you. you will have to disconnect your brake lines tho, causing you to have to bleed your brakes.
If we have to bleed the brakes I'll probably remove the calipers and paint them at the same time... Oh what a slippery slope this will turn into...
yep. i know how that is. I just decided to take my calipers off and repaint them... turned into getting powerstop drilled/slotted rotors all around and new ceramic pads lolOriginally posted by Lucky SOB View PostThat's what I was thinking... alright we'll be in touch
but yeah just figure out what day you wanna do it and shoot me a txt.
Yeah, I assumed I'd have to do some polishing, I'll post up some pics if I tackle it.Originally posted by Lucky SOB View PostI've just been using it on its own. I've seen the oven cleaner method and that seems to work pretty well also. The scotch brite pads leave the stainless with a brushed look - definitely not mirrored like my tips (see below). To get the mirror finish you have to polish them, no way around it. I may end up polishing mine, I'm undecided right now. What I did just discover is, my Y-pipe is not stainless, but painted aluminized steel. I'll probably scuff it up and hit it with a fresh coat of high heat silver paint.
As far as rear end, I swapped mine twice in the old v6 car and it wasn't bad at all, it helps when the car hasn't seen any bad salt/michigan winters. Shouldn't take you more than a couple hours to mess with if you take your time.
As for suspension, I purchased founders performance single adjustable LCAs off ebay, they were the cheapest I could find new and seem to be very good quality. I believe they sell a package deal with the panhard bar for even cheaper (but I had already purchased one from another brand). If you are going to do LCAs you might as well purchase some bolt in relocation brackets as well...-Derek-
Yeah, was talking with Ryan earlier and he recommended Founders also. Your ebay ad looks like th best deal including shipping. Thanks Derek!Originally posted by Derek View Post2000 Trans Am l 1967 Firebird
