i have a 1994 3.4l v6 camaro that has a real good body but my motor went bad. I know where i can pick up a cheap 1993 Z28 that is crashed. What all would i need to change to make the swap happen. I have heard lots of different thing about the dash harness can somebody please help me out.
v6 lt1 swap
Meissen is doing an identical swap as this, he'd be your best source of knowledge. Hes right in the middle right now, check out the project thread.
http://www.mifbody.com/vbulletin/sho...668#post403668-Derek-
x9 trillionOriginally posted by redfbird99 View PostMeissen is doing an identical swap as this, he'd be your best source of knowledge. Hes right in the middle right now, check out the project thread.
Be ready to read 100+ pages
its simple... trans needs to be changed, computer, wireing,, the front engine cradle and radiator. that should do it. but dont forget the engine. its really not hard, me and 2 guys did my swap in two days.sigpic
Yup, not too much as long as you don't go overboard like I did.
Engine, radiator, radiator fans, heater hoses, trans, engine cradle, drive shaft, engine harness, computer. Rear end isn't really a must, you'll just have a low gear and an open diff. Honestly, if you could get a 1994 LT1 engine that'd be the best - the 93 is so different than the 94 which is different than the 95 which is different than the 96-97. Mild differences, but still.- Brian Meissen
The 93 z28 i found i can pick up for $1300 with a cracked fender and a smashed up quarter panel. Does anyone know of 94 z28 i could pick up that cheap because i would rather do that and if not what are the difference between the 93 and the 94.
93 also does not have a MAF, the fuel rails do not have the cross over at the front of the intake manifold, the PCV system is different than in 95, etc. From a swap standpoint, yeah as long as you have the matching harness and computer no big deal I guess.- Brian Meissen
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
V8 pwr
Ya check out B's thread
He also has one on here that is just the build and not all the "that looks good B" in it.
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
If you can get the 93 for that or less its not a bad deal. How many miles on it and does it run good? If so, you have everything you need. Kframe with suspension, trans, drive shaft, and rear end, computer, wire harness. The biggest reason most are negative towards 93, 94's is the Optispark, its not vented and were prone to fail at a higher rate. 95 through 97 were vented and better. 98 and up ar LS1'ssigpic
it has 144,000 miles but i would change all the bearing, rings and gaskets on it. The guy told me it ran good but he didnt have battery so i didnt hear the car run but i would make sure that it did before i bought it.
