408 lt1 helo
    I don't know how people can do that, I research something to death before putting down my hard earned dollars. Hell, it took me 2 months to pick out a damn snowblower.
      I HEAR YA BUDDY....
        Why would you need one with a 4x4 Dakota? Save it for a 9 inch??
        88' Trans Am 350 TPI
          Theres a guy around me
          That has like a 454 or something like that bored out of a lt1 motor its retarded. The car is a old chevy hot rod chopped forget what year. But the thing is stupidly fast man. I didn't know we had room to mount a turbo in the front like that. weird
            I've never seen a LT1 larger than 396 cubes before. Your turbo kit will easily make your horsepower goal on a 383. Good luck with the build, take some more pics of that turbo kit.
            1997 Trans Am
            www.fquick.com/transampimp
              Lol....3 times I had to hook up a tow strap to my girlfriends car last winter to drag it up my driveway....that's why. Gotta keep the girl happy Matt.
                Very true, but let's try and help him make the best of what he has. Here is the direction I would go if I was doing the build.
                Eagle 4.000" 4340 Forged Crankshaft
                Compstar 6.000" H-Beam Connecting Rods
                Diamond Pistons
                Total Seal AP Series Rings
                ARP Main Studs (Splayed 4 Bolt)
                Callies Splayed 4 Bolt Main Caps
                Clevite Main Bearings
                Clevite Rod Bearings
                Clevite Cam Bearings
                ARP Head Studs
                Trickflow 215cc CNC Ported Cylinder Heads
                Cometic Head Gaskets
                Comp Cams Pro-Magnum 1.6 Rockers
                Trend Pushrods
                Comp Cams "OE" Lifters
                Custom Comp Camshaft
                Cloyes Timing Set
                Meling HV Oil Pump
                Meling Oil Pump Pick-up
                Moroso Oil Pan
                Canton Fabricate Valve Covers
                CSR Electric Water Pump
                Edelbrock Air Gap Port Matched
                AS&M Monoblade Throttle Body
                Mototron 60# Fuel Injectors
                Lower End Gaskets Felpro-CS9966
                Intake Gaskets Felpro-MS95580
                Exhaust Gaskets Percys-66031
                Ouch, sounds like someody didn't do thier homework before buying parts.8-O
                  damn thats one hell of a list
                    Yep that is a hell of a list, but that is everything. Ofcourse the list can be modified, and items can be deleted.
                      Ha, you're really taking one for the team there James!
                      Back to the motor,
                      what part of the crank will hit the cam? couldn't you use a 5.7 rod and cut down the counterweights a little?
                        Originally posted by Superman09 View Post
                        I suggest having someone do the shortblock for you. Its a lot of work to build your own and you need to have the block machined and the assembley balanced, etc etc.
                        Well after all most shooting my self.lol. I just wrote the guys back and see if i can do a swap for a 3.8 or 3.85 stroke crank.
                        So this is the thing . the 4 inch stroke is in the grage right now. unopened and all.
                        1. Should i just pay the money to make it work? i dont mind custom pistons
                        2. Will the 1pc crank work in side of ( or bettter)a tbi 350 or late 70's carb 350? We have a carb 350 in the old school 1947 out of a truck and a 1987 tbi 350ci in a turck.
                        3. leave grage and see whats next?
                        I would like to use the crank. I dont realy no what u mean by a small circle cam. i am guessing low lift. so what u mena by that?
                        1993 Camaro
                        th-400
                        3.4 to lt1 swap
                        stand alone wire harness
                        coming soon ( just ask)
                        home made S400 frount mount turbo on the way
                        397ci 9:1
                        Goal 750rwhp+
                          WEll i did my home work on the motor set up for the most part. I found some rods and a company that could get me some custom Dish pistons like srp, je and etc brand for under $100 a piston. Also I new the block we need some clearing. my thing was now if the stroke would have the piston poping out the whole a lil bit.
                          I have the lt1 in the car. I was just realy planing on the stock lt1,k member and turbo be installed for now. then some time after every thing is mocked up and runing then have the short block done, Hot parts jet hot coated, and etc.
                          If the crank will work. that would be nice. I mean its a 408 spooling a turbo . I dont need a nasty cam .
                          1993 Camaro
                          th-400
                          3.4 to lt1 swap
                          397ci 9:1
                          Goal 750rwhp+
                            Diamond Pistons
                            ARP Head Studs
                            Trend Pushrods
                            Cloyes Timing Set
                            Meling HV Oil Pump
                            Moroso Oil Pan
                            I notice their is not a price next to all them things.
                            I was thinking stock intake 58mm tb
                            egale h beam 6.0 rods w/L19 bolts
                            copper headed steal gaskets
                            stock cast iron heads
                            4 bolt splayed mains
                            somthing more along them lines. You think you can do something along them lines. Also I was not thinking electric water pump. i hear those are not good ideas for lt1 motors .
                            1993 Camaro
                            th-400
                            3.4 to lt1 swap
                            397ci 9:1
                            Goal 750rwhp+
                              First of all a small base circle cam means that literally the base circle is small so you dont hit your cam with a rod.
                              Now with your set up...
                              In my opinion your asking for a lot of trouble! Like VRE tried to point out theres some pretty good reasons you don't see too many 400+ CI LT1's, reasons such as destroying your block. What kind of shape is your block in? did it have a lot of miles on it? As for the rods personally I wouldn't feel very comfortable grinding on them. And at the end of the day on top of all the many ways you could get screwed,you want to boost like theres no tommorow. If i were you i would look into a more proven and reliable set up, such as a 383 or a 396. Just tryin to look out for ya bro!!
                              - Mike
                              1996 CAMARO Z\28 M6
                                -Stock intake will work for a while, but in higher horsepower application you will notice the rear two cylinders running lean using that manifold. The Air Gap is suppose to be a little better,and the only real fix is going to a single plain manifold.
                                -Eagle rods are ok, but for just about the same price you can get Compstar rods. The Compstars have a smaller "shoulder" and require less clearancing on the block.
                                -Cometic MLS gaskets work well, but you need to make sure you prepare the surface to a finish of 50 RA (roughness average) or finer, so they properly seal. Anything rougher may conflict with the gasket design.
                                -Are you atleast going to port the stock heads? We have make upwards of 550rwhp with stock unported heads, and we plan on trying to make 700rwhp or so with the newly installed YSI blower and fmic. Unfortunately we don't have any test results yet, so I don't know for sure if they are going to flow enough.
                                -4 bolt splayed main caps is a good idea
                                -We have used electric water pumps on more LT1 engines then the stock mechanical and have no problems. Some people don't like to use them, because they are conceren it will fail and leave them stranded. I feel they are fine and wouldn't hesitate to use it on your project. Also if you want to use a double roller timing set with the stock pump it will cost you around $300 or so. If you want to use a double roller with a electric water pump it is $279, so when you think about it you get 2 new parts for less money then 1.
