408 lt1 helo
  • #31
    We can have Diamond Racing Products make custom pistons for you for less then that.
    Originally posted by Camaroe3 View Post
    I found some rods and a company that could get me some custom Dish pistons like srp, je and etc brand for under $100 a piston.
    • #32
      I have a 383 with an Eagle assembly, SIR Ibeam Rods and a small base cam that has a 108LSA and .568 lift and I still hit my SIR rods with the lobes of the cam.
      Had to grind a little of the top of the nuts & rods to clear the cam
      Now if I can get my trany fixed and a little better tune I should be able to push my full weight 6 speed into the high to mid 11's
      • #33
        Ok. well I just contacted the company that i got the crank from and they have a 30 day retuen policey .
        So now i am stuck with the crank.lol.
        Well you win some and you lost more.
        So now I would like to use the crank and i am sure i am set on have VRE Doing the work on motor wiring.
        would that crank work in any other block? I would not mind buying a nother 350 or 400 block and installing it. We have the 40's chevy coupe needing a power plant.
        what is the psi you think the block could with that crank installed . I would rather make that crank work unless it would be cheaper to buy a $577 3.875 crank .
        I havve also tried to IM VRE but i guess they are not in the shop at 7pm.lol
        1993 Camaro
        th-400
        3.4 to lt1 swap
        stand alone wire harness
        coming soon ( just ask)
        home made S400 frount mount turbo on the way
        397ci 9:1
        Goal 750rwhp+
        • #34
          Well after a few mounths of Bs . The guy down the street have gone gun how on my camaro projet. I just took the pics not to long ago of the k member swap. Every thing is lining up but now i need new lower control arms. the old ones are not coming off and I guess new ones would look beter. Maybe tube lower arms?
          Any who. I am still stressing this crank thing cuz money does not grow on tress in my yard . So VRE Hear i come.
          1993 Camaro
          th-400
          3.4 to lt1 swap
          397ci 9:1
          Goal 750rwhp+
          • #35
            the crank would work in another block, sure, but you wont have an lt1 (no opti provision, for example)
            • #36
              Humm . Well i am lost on that coment. I was just thinking crab 400 block. and just add a efi intake and use a GM HEI to handel the spark.
              We have 2 cars that culd use a nice motor build.
              1993 Camaro
              th-400
              3.4 to lt1 swap
              397ci 9:1
              Goal 750rwhp+
              • #37
                sure you can do that, but you will need a different ecm. the lt1 pcm/ecm will only work with the opti style ignition inputs...
