I have a 383 with an Eagle assembly, SIR Ibeam Rods and a small base cam that has a 108LSA and .568 lift and I still hit my SIR rods with the lobes of the cam.
Had to grind a little of the top of the nuts & rods to clear the cam
Now if I can get my trany fixed and a little better tune I should be able to push my full weight 6 speed into the high to mid 11's
Ok. well I just contacted the company that i got the crank from and they have a 30 day retuen policey .
So now i am stuck with the crank.lol.
Well you win some and you lost more.
So now I would like to use the crank and i am sure i am set on have VRE Doing the work on motor wiring.
would that crank work in any other block? I would not mind buying a nother 350 or 400 block and installing it. We have the 40's chevy coupe needing a power plant.
what is the psi you think the block could with that crank installed . I would rather make that crank work unless it would be cheaper to buy a $577 3.875 crank .
I havve also tried to IM VRE but i guess they are not in the shop at 7pm.lol
Well after a few mounths of Bs . The guy down the street have gone gun how on my camaro projet. I just took the pics not to long ago of the k member swap. Every thing is lining up but now i need new lower control arms. the old ones are not coming off and I guess new ones would look beter. Maybe tube lower arms?
Any who. I am still stressing this crank thing cuz money does not grow on tress in my yard . So VRE Hear i come.
