408 lt1 helo
  • 408 lt1 helo
    WEll i am going to start getting my block put together.
    I have a 1995 lt1 motor
    and Eagale esp 4" stroke 4340 crank.
    The thing is i need rods and pistons and a good cam
    I was thinking some custom -31cc dish and a 6inch rod.
    How tall is the deck on a lt1?
    Will the piston be above the deck?
    what rod you think i should run?
    the plan is still a 75mm turbo on a 408ci lt1 8.8-9.0:1 CR with the th400 .
    So far the motor is on the lift with the motor braced in with the stock k member out. I still have to go down and bolt in the tube k member .
    1993 Camaro
    th-400
    3.4 to lt1 swap
    stand alone wire harness
    coming soon ( just ask)
    home made S400 frount mount turbo on the way
    397ci 9:1
    Goal 750rwhp+
    ive never heard of a 408 LT1 before... is there room for that many cubes in there??
      Well i have a box out in the grage that has lt1 4inch stroke crank shaft. So i am sure it will fit once i get it cleared from the machine shop.
      1993 Camaro
      th-400
      3.4 to lt1 swap
      397ci 9:1
      Goal 750rwhp+
        I just went out side and look at the box. i have not opened it yet. but this is what it reads
        43534000600
        4340 crank, sbc 1pc
        I order the lt1 crank from cnc-proformace a lil while back
        1993 Camaro
        th-400
        3.4 to lt1 swap
        397ci 9:1
        Goal 750rwhp+
          i guess i have to read up on what that actually means. i read LT1 tech forums all the time and ive never heard of a 408 LT1 (using the stock LT1 block). impressive!
            408 = 4.030 bore x 4.0 inch stroke
            396 = 4.030 bore x 3.875 inch stroke
            43534000600:
            4340 Material
            350 mains
            4 inch stroke
            6 inch rod
            Maybe VictoryRacing can tell us why they offer a 396 and not a 408?
            88' Trans Am 350 TPI
              43534000600:
              4340 Material
              350 mains
              4 inch stroke
              6 inch rod
              Well i just read this
              "Eagle SBC 4340 4" stroke crank, this is a 1 pc seal crank, standard main and rod journals. Standard 2.1 rod journals, 2.45 main journals. This is made to go into a late modem 1987 to 1997 350 block, there is extensive clearancing required, but the use of lightweight rods, require less grinding. You can also use SIR rods, with a small base circle cam and there is less blocks clearance required. "
              So how much you think that block work is going to run? and what happened to that shop that was in clinton or waren?
              I live In bellville,mi 48111
              1993 Camaro
              th-400
              3.4 to lt1 swap
              397ci 9:1
              Goal 750rwhp+
                Anything bigger than a 383 or at most a 396 isn't worth it due cost ad complexity of the build. You will definietly need a custom SMALL base circle cam to clear, a good block with no core shift and the ability not to hit a water jacket when you clearance the block. The extra couple of cube isn't really worth it in our opinion.
                  We are in Clinton Township
                  35210 Automation Dr.
                  Clinton Twp, MI 48035
                  (586)741-0158
                    I suggest having someone do the shortblock for you. Its a lot of work to build your own and you need to have the block machined and the assembley balanced, etc etc.
                      To we count as "someone"?
                        Splaied 4 Bolt
                        I think your insane!!
                        The machine work alone for a 383 is about 1000-1100
                        The extra work you should just do a LSX motor
                          If i was you, I would just build a 383, If you do the 408 You could run into some problems that your not expecting.
                            Ouch, sounds like someody didn't do thier homework before buying parts.8-O
                              I SEE THAT ALOT
