need a full bolt ons list and gains estimate
  • #31
    Hell Im having more fun putting parts on (engine, susp, brakes,etc...) and driving it for now. When I start adding things that will require a tune then I will look into a dyno pull. Im excited to see what the SS will do but Im not that concerned about it. I know I can beat up on almost any rice burner. You know how to drive YOUR car and make it perform as well as it can. Id say just keep adding things and then see where it all lands you
    Go BIG or go HOME!
    • #32
      Only reason I say it sucks is because I thought for awhile it would atleast have alittle more
      Then that lol.
      But you're right joel. I'm running 12s so it really doesn't matter
      What my car made stock.
      And I agree with you [MENTION=4302]SOPES[/MENTION] it is fun putting the parts on and after
      Each one felling yourself sink further and further into the seat.
      • #33
        youre running 12's with your bolt-ons?! i ran 13.9 when i got my car last year, with a ported intake and hot air intake. although that was bad opti, iffy on the clutch, tires spinning, 2.73 gears, stock exhaust with blown out cat and a couple extra problems. this year ill have 4.11's, cleaner opti, longtube headers, glasspack mufflers, AC delete, A.I.R delete, my own custom cai, and maybe a short throw shifter and/or drag radials.
        • #34
          A 13.9 isn't too bad. Especially with a bad opti....
          When I ran that 12 it was with radials 3:73s and I hooked up
          Really really well.
          • #35
            re
            [MENTION=3886]dirtybird[/MENTION] I like your formula... if you ever want a mid 12 sec
            Car I'd be interested lol.
            Onlything I'd keep would be my wheels and TB
            • #36
              lol sorry, we're in love, there's no tearing us apart and i'll get in the 12's eventually, i still dont know what im gonna run this year
              • #37
                Picking up long tubes monday, hopefully I gain some lowend power.
                • #38
                  hell yeah. what do you have planned for the rest of the exhaust?
                  • #39
                    If anything youll pick up top end power. If you are lacking low end power with a stock engine something isnt right. I could light the tires off idle when my engine was stock.
                    • #40
                      This, these are torquy motors stock.
                      2002 Z28 Camaro A4
                      • #41
                        My black car is straight legit down low.
                        • #42
                          I can smoke the tires off my car from a dead stop no problem. But it just feels
                          Like I'm lacking the power in the lower end that I have uptop.
                          Maybe I'm nuts idk. But it feels like I can't leave 100ft of rubber
                          Anymore like I used to. Maybe its just sticky tires.
                          But found out the headers I'm getting are dynatech longtubes that
                          Turn out to the sides.
                          So I'm thinking about making the collector into a cutout and adding
                          On to the side of it to run the true duals alittle more straight.
                          Or I might just change the collectors out to straight ones
                          • #43
                            out the side?! thatd be sick! run sidepipes down the running boards! if i didnt have my headers in already id offer to trade ya!
                            • #44
                              For low end, just curious have you run fuel cleaner through the injectors ? cleaned the throttle body ? what are your plugs gapped at and what plugs ? do you still have cats ?
                              Go BIG or go HOME!
                              • #45
                                yes, clean your tb! i took mine off and cleaned it for a good half hour, scrubbing every inch of it with a toothbrush. ran noticingly better after. also check your plugs/wires for sure. have you ever replaced you opti?
                                edit: check your maf, tps, iac, etc. and o2's aswell
