need a full bolt ons list and gains estimate
  • need a full bolt ons list and gains estimate
    Ok so I need a list of FULL bolt ons.
    And what kind of gain you had with full bolt ons vs stock.
    I'm thinking I have full bolt ons but I'm not sure if I'm missing
    A minor bolt on or two.
    I know I want to delete A/C and put a pully on it.
    My A/C works but never use it.
    And the throttle body bypass mod
    But I have headers, slp lid, ram air, exhaust system,
    Gears, stall, TB, fan switch, msd coil, ported intake.
    Egr delete. Built trans.
    Need to know if I'm missing anything
    Probably not much, .2 maybe with the removal of everything. Best bet is gear.
      Suspension pieces. Cold air intake.
      When in doubt, Whip it out !
        Throttle by pass will get you 1 or 2 hp when its up to operating temp. The downside is if you drive it in the cold it can cause driveability issues and will cause build up of carbon in the throttle plate.
        How about underdrive pulley ? SSRA air intake ?
        Go BIG or go HOME!
          I have a k&n high flow filter and I cut the lower air lid to allow air from
          The bottom in and from the ss hood.
          What I meant by gains is Horsepower gains for each bolt on
          And if I have full bolt ons.
          If I remember correct... anything that touches the engines oil
          Is NOT a bolt on??
            re
            Oh and a final hp rating.
              Don't forget to tune it. You can throw on every part imaginable, but if it's not tuned correctly, you're not getting what you should out of it. And start looking into suspension and rigidity items. All the HP in the world means nothing if you can't transfer it to the pavement, safely.
              2002 Z06 - Electron Blue Metallic - D1 @ 14psi - E85 - Forged - Kooks LT's - Kooks exhaust - RPS clutch - RPM trans - 100# ID injectors - Holley 12-1400 Dominator pump **701 RWHP 687 RWTQ** || 2014 Silverado Z71 5.3: A6 Blue Topaz - OEM || 2002 Z28: M6 NBM **sold**
                ful bolt on cars make anywhere from 330-mid 350s rwhp.
                  He is lt1
                  2002 Z28 Camaro A4
                  1993 Z28 Camaro M6- SOLD
                  1999 Z28 Camaro M6- SOLD
                  2008 Ford Fusion SE - DD
                    my bad the lid comment threw me off, in that case just sell it
                      from what i"ve seen on other sites full bolt'ons and a good tune on an lt1 with an m6 should make around 300rwhp
                        Hard to agree when Joel's cam only is putting down ~373 or 376? Somewhere in there.
                        2002 Z28 Camaro A4
                          The other problem that guys get confused on is sometimes you cant add the hp rating of each part, some items work with another one and If you go by what mustang guys add up the numbers are really off, they add the highest HP rated number of each bolt on and thats how they end up coming up with a few bolt ons giving you 120 hp. Not trying to rain on your parade. Tuning after all of the bolt ons would be your best bet
                          Go BIG or go HOME!
                            i'm guessing Joel has all the supporting mods including the majority of the boltons one would normally do before or while in a cam swap. I also believe he'd have to have head work done and a bump in compression to achieve those numbers. I'm not sure on his setup. Maybe Joel can chime in.
                              A cam swap can easily add 70hp when using good parts. Seeing as he added a point of compression while the heads were off I think its pretty safe to say he was in the 290-310RWHP range with just bolt ons.
