just wondering what a 4L60E would be worth, pulled out of my 97 trans am. it throws a CES code saying "transmission component slipping" but drives fine. what do they go for?
4L60E Worth?
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
Bought the last two for $75 and $100. Is it two piece?
$75 one will not shift 2-3 at WOT (so I'm told) but works great otherwise and the $100 one cracked the vane rotor in the pump, the trans had 10,000 miles on it after a TCI rebuild.
before mine was replaced it didn't shift 2-3 only at WOT for some reason. It made it another 2-3 years before it actually started slipping the gears, but when it went bad it was instantly noticeable and nearly undriveable. You might be able to get use out of it.Originally posted by hoogiesngrinderz View PostBought the last two for $75 and $100. Is it two piece?
$75 one will not shift 2-3 at WOT (so I'm told) but works great otherwise and the $100 one cracked the vane rotor in the pump, the trans had 10,000 miles on it after a TCI rebuild.2000 Firebird A4 black hardtop
~Phil
