best rods for the cost? blown motor? WTF?
  • if u wanna be at my house by 9am. not doing it here, doing it at another location but you are more then welcome to join. im in grant about 5 minutes away. text or call my cell. 616-723-5918
    - - 5.3/4L80e/T7875 - -
    - Huron Speed Turbo Kit -
    1998 Formula
    • Good luck fellas. Hoping to see some engine-out pics by noon
      • '91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
        • good luck keep us updated on what you find out
          00 Tahoe Z71........Stock
          • Should of posted sooner mike. We got pretty messed up last night.
            Got it out yet?
            • answer your texts monty
              • ls1 rebuild 016.jpgls1 rebuild 001.jpgls1 rebuild 003.jpgls1 rebuild 004.jpgls1 rebuild 006.jpgls1 rebuild 007.jpgls1 rebuild 008.jpgls1 rebuild 010.jpgls1 rebuild 011.jpgls1 rebuild 012.jpg
                well looks like #6 spun and on its way out due to #6 was #5. crank is beat to hell and unsure on rod at the moment. #6 piston hit the head but very slightly, both should be fine. #6 bearing was spun almost all the way around. #5 was about a 1/4 in around. the way that the bearing was wore shows that it wasnt installed properly or the arps had distorted the rod causing uneven wear. will try and get the parts to the builder and see what he says
                1998 Formula
                • That don't look good
                  • Not good mike!! I would see what paul has to say about it. hopefully it wasn't builder error. Might think ya reconsider one of my previous posts.
                    • happen to have a pic farther away? i want to see more rods still in the engine
                      • i dont at the moment but my short block is in the garage. i can take a couple more tomorrow morning.. im hoping paul takes responsibility for this, if not ill pay to have my parts machined elsewhere and assemble myself.
                        i only pulled the two and will be letting the builder disassemble the rest
                        1998 Formula
                        • Ouch...
                          • Yea hopefully he does who knows let me know if he does.
                            Assvly your self is the best thing no one to blame but yourself
                            • im pretty sure i know what he did. does anyone else see it?
                              a bigger pic would confirm
                              • Now you have me worried about my motor. If a builder can do this, no telling what I can do...yikes.
