Making my own fiberglass cowl hood
    very nice job
    00 Tahoe Z71........Stock
      Thanks guy's
        Looking great so far. It doesn't look like you're filling the corner/crevasse between the scoop and hood... why?
          It will be caulked with a body seam sealer. Getting closer to that point.
            Did a test fit with the new air cleaner. The steel hood is still on it so I couldn't close it the hole is to small. I bought a 16" aluminum pizza pan and cut a 12" hole in it. Then I screwed it to the bottom of the base so the screws are under the seal of the filter. Then I put a seal around it. I will also put the same type of seal around the hole in the hood so the two mate together.
              wow thats actually really smart.
                thats cause he has some enginuity (ingenuity) skills just like me !
                ingenuity n. , pl. , -ties . Inventive skill or imagination; cleverness. Imaginative and clever design or construction: a narrative plot of great.
                  thats mint!
                    i am loving it looks great man
                      any updates on this.. aka more pics please
                        3 new pics after the seam sealer, and a little sanding.
                          That looks great!
                            looking good
                            2005 Goat - Grass fed.
                            1996 Camaro RS Vert. - Parted out and sold!
                              looking good! keep up the good work, cant wait to see it all complete and on the car... oh dont forget to check and replace your furnace filter if its full fiberglass, bondo dust
                                Put some ppg high build primer over the bodywork and seam. I applied it with a foam roller for good build up. Then I will block it down and reprime it.
