very nice job
Making my own fiberglass cowl hood
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
00 Tahoe Z71........Stock
Did a test fit with the new air cleaner. The steel hood is still on it so I couldn't close it the hole is to small. I bought a 16" aluminum pizza pan and cut a 12" hole in it. Then I screwed it to the bottom of the base so the screws are under the seal of the filter. Then I put a seal around it. I will also put the same type of seal around the hole in the hood so the two mate together.Attached Files
thats cause he has some enginuity (ingenuity) skills just like me !
ingenuity n. , pl. , -ties . Inventive skill or imagination; cleverness. Imaginative and clever design or construction: a narrative plot of great.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
thats mint!-Joel
i am loving it looks great manThe Original
looking good! keep up the good work, cant wait to see it all complete and on the car... oh dont forget to check and replace your furnace filter if its full fiberglass, bondo dust'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
