97rs4life Engine Swap
  • #61
    well its been 2.5 hours. where's the results?!
    • #62
      • #63
        tried it out and it is better, no more TPS and high idle codes. Still searches a little bit at start up. Playing with the tune will help that. At least now I get a tps reading and such.
        I will get vids when it is daytime, can't see squat at night
        I am still debating whether to run down to zzp and have them tune it on the dyno so I don't have to worry about figuring it out exactly. They know how to dial these cars in
        5th gen Camaro V6 Forums
        http://www.bowtiev6.com
        • #64
          might be worth it
          • #65
            I can't wait to see/hear this beast myself. Let us know (I may be a little behind on all of this).
            • #66
              yeah hows the progress going travis?
              • #67
                yea been so busy lately that it has taking a back seat to work and other things. Hopefully this weekend I can dig back into it again. Need to at least get it on the dyno before winter snow flies
                • #68
                  Get it done, sir!
                  • #69
                    Is the motor bolted on at a slant in these pics? How many bolts do you have securing the passenger side to the k-member?
                    • #70
                      My guess would be its just turned a bit on the engine stand its mounted too....
                      • #71
                        Hey guys thank you for the reply. Warshrike on LS1tech shared his install pics with me and it appears that
                        1. There is a nut welded to the backside of the mount pad on the top right bolt hole that I need to grind off to install correctly.
                        2. One of the bolt holes I was trying to use on the bottom right was incorrect.
                        • #72
                          Let kn know how the poly mounts work for you. I figured with my build, there would just be too many NVH issues.
                          • #73
                            All the RWD cars I've been in with poly mounts haven't really been too noticeable - my car, on the other hand...
                            • #74
                              Sorry guys, the pics are not of my car. They are Warshrike's car. I am reposting them for reference.
                              • #75
                                yea it was the engine stand tiltling it a bit, all the bolts were mounted up on the brackets. I couldn't use the poly aftermarket ones that I picked up, didn't fit right, stuck with the OEM ones and it was fine
