well its been 2.5 hours. where's the results?!
97rs4life Engine Swap
tried it out and it is better, no more TPS and high idle codes. Still searches a little bit at start up. Playing with the tune will help that. At least now I get a tps reading and such.
I will get vids when it is daytime, can't see squat at night
I am still debating whether to run down to zzp and have them tune it on the dyno so I don't have to worry about figuring it out exactly. They know how to dial these cars in------------------------------------------
5th gen Camaro V6 Forums
http://www.bowtiev6.com
might be worth itOriginally posted by 97rs4life View Post
I am still debating whether to run down to zzp and have them tune it on the dyno so I don't have to worry about figuring it out exactly. They know how to dial these cars in2011 Ford Raptor SuperCrew
yea been so busy lately that it has taking a back seat to work and other things. Hopefully this weekend I can dig back into it again. Need to at least get it on the dyno before winter snow flies------------------------------------------
Get it done, sir!- Brian Meissen
Hey guys thank you for the reply. Warshrike on LS1tech shared his install pics with me and it appears thatOriginally posted by ITSSLOW View PostMy guess would be its just turned a bit on the engine stand its mounted too....
1. There is a nut welded to the backside of the mount pad on the top right bolt hole that I need to grind off to install correctly.
2. One of the bolt holes I was trying to use on the bottom right was incorrect.
Let kn know how the poly mounts work for you. I figured with my build, there would just be too many NVH issues.Originally posted by phoenix_rising View PostHey guys thank you for the reply. Warshrike on LS1tech shared his install pics with me and it appears that
2. One of the bolt holes I was trying to use on the bottom right was incorrect.sigpic
All the RWD cars I've been in with poly mounts haven't really been too noticeable - my car, on the other hand...Originally posted by steddy View PostLet kn know how the poly mounts work for you. I figured with my build, there would just be too many NVH issues.
yea it was the engine stand tiltling it a bit, all the bolts were mounted up on the brackets. I couldn't use the poly aftermarket ones that I picked up, didn't fit right, stuck with the OEM ones and it was fine------------------------------------------
