Definately one of my favorite build threads...good to see it nearing completion!
97rs4life Engine Swap
Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
engine is getting fired up tomorrow. I was going to do it tonight but had some leaks that I had to take care of during testing of some things.
So tomorrow morning I will head back out and finish it up and then flash in my new tune for the new engine.
Any recommendations for engine break in? I have had a few guys tell me to give it a few good bursts up to like 5k rpms to help seat the springs and such.
Also do I need to do anything to prime the oil before initial start up or anything? How about a case relearn with hptuners?
I will finish making the cold air intake after I get it running. Also will need to hook the exhaust up again too. It is open headers right now as I haven't put my ypipe back on yet
Alright, time for some more pics to keep you all happy.
5th gen Camaro V6 Forums
http://www.bowtiev6.com
that is sick. you will need a vid of the start up!2011 Ford Raptor SuperCrew
unless you have some kind of special spring, 5k RPMs is definitely not what you want to be doing right away. Ron at advanced induction told me to fully heat cycle my engine [springs] 3-7 times before doing any high RPM pulls. (and I have read this elsewhere also). When people break springs right off the bat, its usually failure to break them in properly as RPM is typically the only cause of failure for a spring.
I primed my oil pump with the spark plugs and coil wire removed... of course you can get by with just the coil wire. It took me two tries, my starter began to overheat right about the second it got pressure. Definitely a very good thing to do before starting a fresh motor.Last edited by JoeliusZ28; August 30th, 2008, 02:39 AM.-Joel
I think I am going to just pull the wires off the plugs as they are easier to access then my coils then. Thanks for the advice on getting it to prime------------------------------------------
Just pull the fuel pump fuse and roll the motor over for 10-15 seconds, no need to mess with spark plugs wires.....then fire it up. Rings have to be seated under load..ie, road time. Don't let the engine sit around in the garage at idle too much....the cylinder walls will glaze up and the motor will burn oil for the rest of it's life.sigpicTurbo Charged LS1/T56
well I pulled the plug wires, cranked a few times to build oil pressure up, then put the plugs back on. checked fuel connections for leaks and have nothing. Hear the pump running and fuel press. gauge shows there is fuel at the rails. I go to fire it up and nothing. It tries to turn over but doesn't fire. The starter is turning over but the engine is not firing up.
Any ideas with what to check? I am stumped right now
Last edited by 97rs4life; August 30th, 2008, 01:16 PM.------------------------------------------
thinking my battery is shot. Going to swap it out here shortly and find out as I was using the jumper box before on it------------------------------------------
That would be my guessOriginally posted by 97rs4life View Postthinking my battery is shot. Going to swap it out here shortly and find out as I was using the jumper box before on it2011 Ford Raptor SuperCrew
just makes me nervous as my oil gauge hasn't gone past like 10-15 during the turn overs. Hopefully it jumps to 60 once it is fired as I cranked it a bunch already so oil should be pumping------------------------------------------
