Texas Speed Moser 9 Inch
  • #76
    For the right price.
    Your still looking for a rear B - you should have bought mine a few years ago
    Jay - the brake caliper mounts need to be assembled in the right order on the axles. If i remember correctly axle flange>brake mounts>then the bearing get pressed on. Moser should be able to help you over the phone. Typically the brake mounts are expensive - that's why they aren't included.
    2000 Formula
    fixed slow junk
    • #77
      It's for Angie's car actually. Her rear whines, always has from the factory. We've had it torn apart and guts "fixed" but so far haven't had any success getting the whine to go away.
      • #78
        Yeah I remember talking to you about it. That sucks - good luck finding one!
        2000 Formula
        fixed slow junk
        • #79
          Found on an old DIY thread talking about building your own 9 inch with parts from Moser and others back when it was first introduced for our cars, it states that you can have moser weld them the backing plates on the shafts for a couple hundred or have a local welder do them. Ill find someone thats good locally; theres plenty of reputable places in michigan. I'm just curious is anyone else ran into this problem and what they did. Thanks guys
          98' Formula M6..Texas Speed PRC 5.3 2.5 Head..Comp 228R .588/.588 cam..180* Thermo..Stenod tune..L/T's..O/R-Y..Dynomax Ultra-flo w/ elect cut out..LS6 manifold..Lid..B&M..Hotchkis LCA's..Moser 9-inch with 4.11's..adj. tq. arm..chrome z06 wheels
          • #80
            nothing needs welded. press the bearings off. install brackets/ backplate and reinstall the bearing
            • #81
              http://shop.brutespeed.com/Moser-12-...structions.htm
              • #82
                Thanks..GREAT info!
                • #83
                  What are you doing with the rear end that's currently in it, Jay? Is it blown?
                  FYI axle is out, not completely sure what its worth but have some idea based on the feedback some have given me on here. Send me a message and lets work something out. I want that 10 bolt gone and never to be seen again! lol just happy someone can still find a use for it! Let me know.
                  • #84
                    PM sent.
                    • #85
                      PM sent.
                      Reply sent
