I just removed my third gen tank. I am picking up a plastic fourth gen tank this week. Any tips for the install? Anyone running braided lines to the fuel tank?
LS1 fuel tank swap help
Enthusiast- January 1st, 2009
- 342
- Chris
- 1987,Chevy,Camaro(IROC)
- Jenison, Mi
- Gentex production maintenance
Air Force/Afghanistan veteran
1987 Iroc camaro Supercharged 5.3
2012 Toyota tacoma -
- 342
- Chris
- Jenison, Mi
Yeah I was just seeing if anyone local had any tips. ThanksAir Force/Afghanistan veteran
2012 Toyota tacoma
Honestly, TGO has every piece of info you need to complete the swap. It's not really worth your time to post a thread about it here, as there are really only one or two people on MiFbody who may have even of done the (fuel tank) swap. Good luck with the project!
Edit- You can check out James' thread about his LS1 swap. There are a few cool little things he posted while building it:
http://www.mifbody.com/vbulletin/sho...way&highlight=Last edited by Iroc'nthe87; December 28th, 2014, 10:24 PM.Makin Torque.
its pretty easy, however its easier to run the stock tank, and yes I ran stainless braided line, I too read a lot of tips on TGO even using the search function over there too.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
Post Whore
- January 14th, 2015
- 1286
- Dan Dalessandro
- 1997 Camaro Z28
- Troy and Port Huron
- Full time student
I believe 99 and up used plastic in 4th gens.Originally posted by NullHead View PostThe 3rd gen tanks are made of steel and rot out, and they use the old style metal fuel sending units, which also rot out. 4th gen tanks are all plastic, making it lighter and longer lastingsigpic
lighter ? uhh Idk about that, might be a couple ounces lighter and you could probably shit the difference in weight
here is some additional info here
http://www.thirdgen.org/forums/ltx-l...k-plastic.html'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
