Worn steering rag joint on 3rd gen camaro - dangerous?
My mechanic has told me not to drive my Camaro because of the worn rag joint on the steering shaft. I'm currently trying to locate a solution, which seems to be the Astro Van upgrade mentioned here http://www.mifbody.com/vbulletin/sho...upgrade!/page7
but haven't yet heard back from Darren.
My question is, can I still drive my car ? Is the steering going to suddenly fail on me or anything?
I'll respond to your PM. Sorry I don't really come on here much anymore. I have one on the shelf right now and I have a buddy who wants it. I know there is another in my garage tho. I'll investigate and find it.
the rag piece, the rubber part is replaced with a billet piece. Its going to be same out come as the astro. I'll see what kind of price I can get shipped to you. I didn't realize your so far lol
My mechanic is asking - doesn't the rag joint need to be flexible? and does the shaft need to be modified to fit it? ie what's the labor involved. He also says he suspects the top of my steering shaft is worn so the full replacement astro might be the way to go still...
the astro only replaces the bottom rag joint section. the upper part that the lower slide onto is part of the steering column. You can repack that bearing or replace if need be though
