Does anyone here know how to fix the tachometer problems in the 90-92 gauge cluster. I recently purchased a new/used cluster from a guy on thirdgen.org to replace mine that was constantly pegged. The replacement I received works, but at times is very inaccurate. I found a fix on the thirdgen message boards. Was wondering if anyone locally (Metro Detroit area) repairs these clusters? Please help!
90-92 tachometer issue
Obsessed- June 6th, 2012
- 505
- Brian
- 1991 Camaro RS/1991 Camaro Z28
- Wixom Michigan
- Truck Driver
- 505
- Brian
- Wixom Michigan
- Truck Driver
Ouch! I think I can buy a whole new auto meter cluster for that. Terrible! Someone needs to start repairing these out of their garage. They could definitely make some money. There were 7 pages of responses to this thread on thirdgen.org. The fix that these guys came up with sounds pretty simple.. I'm no mechanic though! Thanks Brian!sigpic
- Greenville, MI
- Die Maker
ship me your old one that doesn't work at all. I can probably get it to work for less than 20 bucks
Micheal, how good are you with the clusters? Would you or could you reset the mileage for me? I had a v6 but went to a v8 cluster for the swap, illegal yes but the car is new, and no intentions on being fraudulent, but since the car is gonna be basicly new, it would be nice to have a fresh start on the mileage.'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
- Greenville, MI
- Die Maker
I've repaired a few tach clusters on third gens and I have reset the odometer in my Bel Air and the 89 Silverado...so yeah I can probably get it to zero out.
Obsessed
- January 13th, 2006
- 593
- C
- It's a big pretty white plane, with wheelz, curtains in the windows and it looks like a big tylenol
- MI
- Engineer
It sounds like Michael has you covered.
However If in the event Michael cannot repair it for you, there are several businesses that advertise on Ebay which repair clusters. The cluster I got for my GMC was mileage matched, had all of the updates, plus additional goodies I didnt have before.
They may have exactly what you need as well.
- 505
- Brian
- Wixom Michigan
- Truck Driver
I pulled the tach and the chip out of the one I bought and put it in my cluster.. Threw the rest away. These guys on thirdgen.org are soldering resistors in over a chip on the board and its correcting the accuracy issues. Is that what you do Michael? I'm not very good or patient with a soldering iron.. lolOriginally posted by hoogiesngrinderz View Postship me your old one that doesn't work at all. I can probably get it to work for less than 20 buckssigpic
- 505
- Brian
- Wixom Michigan
- Truck Driver
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
i got an extra i dont need, come pick it up and its yours91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
- 3000
- Tyler Porter
- student
v6, is their a difference in the 90-92 versions?
at least im assuming its a 691 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
- Greenville, MI
- Die Maker
That's one way of doing it. You can also use adjustable resistors (potentiometer/pot resister) to dial it it.Originally posted by deeznuts94 View PostI pulled the tach and the chip out of the one I bought and put it in my cluster.. Threw the rest away. These guys on thirdgen.org are soldering resistors in over a chip on the board and its correcting the accuracy issues. Is that what you do Michael? I'm not very good or patient with a soldering iron.. lol
what this guy said.Originally posted by hoogiesngrinderz View Post(potentiometer/pot resister)'91 Camaro Modded, LSx, House of Kolor Intense White, lowered, GS chrome 18" wheels, 14" Brembo CTS-V on all 4 corners, LS rear end, FP suspension components
- 505
- Brian
- Wixom Michigan
- Truck Driver
Right. I need to find someone in my area that has done it a few times, So I'll feel comfortable with them ripping apart my dash. lolOriginally posted by hoogiesngrinderz View PostThat's one way of doing it. You can also use adjustable resistors (potentiometer/pot resister) to dial it it.Last edited by deeznuts94; June 7th, 2012, 10:32 PM.sigpic
