Project 421
  • Originally posted by Iroc'nthe87 View Post
    Sounds good Tony! Is that the stock air intake? Pretty sure those things are obnoxiously restrictive..
    port matched First TPI intake and runners, its bigger then the restrictive stockers
    edit: see post 175
    • That's not what i'm talking about.
      Makin Torque.
      • Thanks! Yea for now I plan to run the stock plastic intake y. Plan to revisit that and the 3 inch cat back after I get the tune nailed totally down.
        • What is so special about this First intake? I have never heard of it until a few days ago. Sorry if its off topic.
          1991 Camaro RS: "Tiny Turbo Mullet"
          • Torque city bro
            Makin Torque.
            • Yep Big Block torque in a small block. Makes for a great street car.
              • Gotcha, I also heard it flows much much better than the stock tpi. Torque does make for a fun car.
                • Ordered up some goodies for Christmas, Hooker is making some good stuff for our Third Gens.
                  • Sweet!
                    • Hooker T56 crossmember vs Hawks
                      Hooker is thicker and puts the torque arm on the crossmember and not the transmission.
                      • looks awesome! I really like the hooker true dual black heart systems
                        • Ran into a little snag the crossmember torque arm bracket hits my manual speedometer conversion on my tail housing. A little modification is in order.
                          • All fixed.
                            • Those little tweaks...looks like a good solution.
                              • Got to get this thing so it can breath, a little something I have been working on this winter. I still need to trim the top and add the rubber seal but not bad if I may say so.
                                Also made a aluminum radiator bracket to better bolt the LT1 Fan shroud in place.
