I got a paint supply warehouse down the street from my work and he gave me a great deal on paint and supplies. (Less then cost to places like Finish Master) Only down fall is I have to buy in gallon amounts, but the plus is it still only cost me $100 for supplies to do the engine bay. I can get the base color in Qt. size. Won't be running out of clear coat anytime soon. He made me promise to not tell any companies what I paid.
Project 421
Fuel lines done. Alternator and Power steering hooked up.
Bolted on the rest of the FIRST intake and sensors plus adjusted more wires.
Not much left on the wiring and only need to get a new throttle position sensor and I should be able too drop in the battery and make sure all the sensors are talking to the EBL Flash ECM.
Very nice project!-Joel
Obsessed
- December 28th, 2005
- 931
- Friends call me Cat.
- '87 305 IROC Z Bride nick named my ride as "The Ole Whore". IDK, jealous maybe?
- Jackson
- Civil Servant
I commend you on doing a very nice, and through job!
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
make your own91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
Hard to say use the stock one when that custom one you posted as an example looks so good!- Brian Meissen
- Lowell, MI
- Meat Processor
That FIRST/TPIS intake setup will flow some serious airOriginally posted by Iroc'nthe87 View PostDitch that entire thing..it's going to choke down that engine big time. Hell, it's restrictive on stock engines.
