has anyone on here done a 4th gen rear end swap in a 3rd gen if so what did you do to bolt it up i heard it just a drop in type thing however do i need anything esle and will my 3rd gen stuff work... shocks and springs and will the 4th gen ebrake work
sorry my title is messed up so i fixed the post
Everything bolts right up.....minus the parking brake...that you have to use a little engineering on. Then you will have to run a set of 4thgen wheels on the rear too....because it's 2 inches wider.
Everything is drop out and bolt up jon, you will need to replace or "engineer" that brake line as I was telling you and remove the elctronics of the 4th gen rear. But other then that it should be simple, and like stated above it will be 2 inches wider and you will need to run 4th gen rims (I believe) so that means someone named Darrenscamaro can take the ones you have on your car now...
