i'll have to take a look, i don't have door panels so it should be easy. with my luck they are probably broken.
Terrible window gap.
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
Mcalus and your big brain get out of here!Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
Lurker
- March 13th, 2010
- 3476
- TJ
I tried it wont come off. Next step is sand paper.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
am i looking for where the window hooks to the regulator track? they both looked to still be hooked on so i'm assuming i'm missing something.sigpic
Inside the door the regular is a scissor-style X-shape looking thing.... aka the regulator. At all four corners of the X there are the knobs mike is talking about. They articulate in tracks that run horizontally in the door. Just make sure one of those hasnt broke or come out of the track.
Also, there ARE several adjustments for the window regulator. One of them determines how firmly the window presses against the seal. If the entire window isnt firmly seating... this could definitely be your issue too.-Joel
Ok I'll check again tomorrow. I wish this damn car just had crank windows, electric ones are such a PITA.sigpic
No you don't! I've been down that road. I converted my car to crank windows to save the whole 1 pound per side and "eliminate the headaches." Didnt work that way.... The crank regulators are just as shitty as the power ones, if not worse. I ended up converting my car back to power because one of the regulators skipped a tooth and it wouldnt close the window all the way anymore even with the adjustment maxed. There was absolutely no way to fix it since the manual regulators dont come apart. Needless to say they ended up in the trash can...Originally posted by formula218 View PostOk I'll check again tomorrow. I wish this damn car just had crank windows, electric ones are such a PITA.-Joel
Damn, okay then it's time for a window net lol.
I looked at where the X hooked to the glass and it looked fine, I'll check the others tomorrow. Hopefully it's not broke because I'm not spending money on a new one.sigpic
Yep, i was going to say the same but figured "eh thats probably more than he wants to spend on a RACE CAR!"Originally posted by mcalus View PostIts like $115 for a new one with a motor.
yeahhh, when it goes bad i guess the window will have two positions, in or out lol.sigpic
It appears from the pics that your door and quarter surfaces don't line-up. You can adjust the striker on the B' pillar to pull the rear of the door in closer and align it with the quarter panel. Loosen it with a large torx bit and slide it in a little at a time to get the door and the quarter surfaces matched. This may take care of a lot of the problem.
