Torque specs for LS1 motors
This is a sticky topic.
  • Torque specs for LS1 motors
    Thought I'd be helpful
    Fastener Tightening Specifications Application
    Specification
    Metric / English
    A/C Belt Tensioner Bolt
    25 Nm 18 lb ft
    A/C Compressor and Condenser Hose Bolt (at Accumulator)
    16 Nm 12 lb ft
    A/C Compressor and Condenser Hose Bolt (at Compressor)
    33 Nm 24 lb ft
    A/C Compressor Bolts
    50 Nm 37 lb ft
    A/C Compressor Bracket Bolts
    50 Nm 37 lb ft
    Accelerator Control Cable Bracket Nut
    10 Nm 89 lb in
    Air Conditioning (A/C) Belt Idler Pulley Bolt
    50 Nm 37 lb ft
    Air Injection Reaction (AIR) Pipe-to-Exhaust Manifold Bolts
    20 Nm 15 lb ft
    Battery Positive Cable Nut (at Generator Output Stud)
    22 Nm 16 lb ft
    Brake Pipe Fitting
    15 Nm 11 lb ft
    Camshaft Position (CMP) Sensor Bolt
    25 Nm 18 lb ft
    Camshaft Retainer Bolt
    25 Nm 18 lb ft
    Camshaft Sprocket Bolt
    35 Nm 26 lb ft
    Catalytic Converter Nut
    25 Nm 18 lb ft
    Clutch Pressure Plate Bolt (In Sequence and Evenly Over 3 Increments)
    70 Nm 52 lb ft
    Connecting Rod Bolts – First Pass
    20 Nm 15 lb ft
    Connecting Rod Bolts – Final Pass
    85 degrees
    Coolant Temperature Gauge Sensor
    20 Nm 15 lb ft
    Crankshaft Balancer Bolt – Installation Pass-to Ensure the Balancer is Completely Installed
    330 Nm 240 lb ft
    Crankshaft Balancer Bolt – First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes
    50 Nm 37 lb ft
    Crankshaft Balancer Bolt – Final Pass
    140 degrees
    Crankshaft Bearing Cap Bolts – Inner Bolts – First Pass in Sequence
    20 Nm 15 lb ft
    Crankshaft Bearing Cap Bolts – Inner Bolts – Final Pass in Sequence
    80 degrees
    Crankshaft Bearing Cap Side Bolts
    25 Nm 18 lb ft
    Crankshaft Bearing Cap Studs – Outer Studs – First Pass in Sequence
    20 Nm 15 lb ft
    Crankshaft Bearing Cap Studs – Outer Studs – Final Pass in Sequence
    51 degrees
    Crankshaft Oil Deflector Nuts
    25 Nm 18 lb ft
    Crankshaft Position (CKP) Sensor Bolt
    25 Nm 18 lb ft
    Crossmember Bolt (Lower)
    145 Nm 107 lb ft
    Crossmember Bolt (Upper)
    125 Nm 92 lb ft
    Cylinder Head Bolts (First Pass all M11 Bolts in Sequence)
    30 Nm 22 lb ft
    Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence)
    90 degrees
    Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head)
    90 degrees
    Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence)
    50 degrees
    Cylinder Head Bolts (M8 Inner Bolts in Sequence)
    30 Nm 22 lb ft
    Cylinder Head Coolant Plug
    20 Nm 15 lb ft
    Drive Belt Idler Pulley Bolt
    50 Nm 37 lb ft
    Drive Belt Tensioner Bolt
    50 Nm 37 lb ft
    End Link Nut
    23 Nm 17 lb ft
    Engine Block Coolant Drain Plugs
    60 Nm 44 lb ft
    Engine Block Heater
    40 Nm 30 lb ft
    Engine Block Oil Gallery Plugs
    60 Nm 44 lb ft
    Engine Coolant Air Bleed Pipe Bolts and Studs
    12 Nm 106 lb in
    Engine Flywheel Bolt (First Pass)
    20 Nm 15 lb ft
    Engine Flywheel Bolt (Second Pass)
    50 Nm 37 lb ft
    Engine Flywheel Bolt (Final Pass)
    100 Nm 74 lb ft
    Engine Front Cover Bolts
    25 Nm 18 lb ft
    Engine mount Bolt
    50 Nm 37 lb ft
    Engine Mount Bracket Bolt
    58 Nm 43 lb ft
    Engine Mount Heat Shield Nut
    10 Nm 89 lb in
    Engine mount Stud
    50 Nm 37 lb ft
    Engine Mount Through Bolt
    95 Nm 70 lb ft
    Engine Mount Through Bolt Nut
    10 Nm 89 lb in
    Engine Oil Filter
    30 Nm 22 lb ft
    Engine Rear Cover Bolts
    30 Nm 22 lb ft
    Engine Service Lift Bracket M10 Bolts
    50 Nm 37 lb ft
    Engine Service Lift Bracket M8 Bolt
    25 Nm 18 lb ft
    Engine Valley Cover Bolt
    25 Nm 18 lb ft
    Engine Wire Harness Clip Bolt
    50 Nm 37 lb ft
    Engine Wire Harness Clip Bolt (at Automatic Transmission)
    2.5 Nm 22 lb in
    Engine Wire Harness Ground Bolt
    50 Nm 37 lb ft
    Engine Wire Harness Ground Bolt (at Frame Rail)
    12 Nm 106 lb in
    Engine Wire Harness Ground Bolt (Left Side of Engine block)
    30 Nm 22 lb ft
    Exhaust Manifold Bolts – First Pass
    15 Nm 11 lb ft
    Exhaust Manifold Bolts – Final Pass
    20 Nm 15 lb ft
    Exhaust Manifold Heat Shield Bolts
    9 Nm 80 lb in
    Exhaust Manifold Pipe Nut
    35 Nm 26 lb ft
    Front Fuel Pipe Heat Shield Nut
    5 Nm 44 lb in
    Fuel Injection Fuel Rail Bolts
    10 Nm 89 lb in
    Fuseblock Stud Nut
    14 Nm 10 lb ft
    Generator Bolt
    50 Nm 37 lb ft
    Generator Rear Bracket Bolt
    25 Nm 18 lb ft
    Ground Terminal Bolt
    6 Nm 53 lb in
    Ignition Coil Bolt
    12 Nm 106 lb in
    Ignition Coil-to-Bracket Bolts
    12 Nm 106 lb in
    Ignition Coil Bracket-to-Valve Rocker Arm Cover Studs
    12 Nm 106 lb in
    Intake Manifold Bolts (First Pass in Sequence)
    5 Nm 44 lb in
    Intake Manifold Bolts (Final Pass in Sequence)
    10 Nm 89 lb in
    Intermediate Steering Shaft Bolt
    47 Nm 35 lb ft
    Knock Sensors
    20 Nm 15 lb ft
    Negative Battery Cable Lead Bolt
    32 Nm 24 lb ft
    Oil Filter
    30 Nm 22 lb ft
    Oil Filter Fitting
    55 Nm 40 lb ft
    Oil Level Indicator Tube Bolt
    25 Nm 18 lb ft
    Oil Level Sensor
    13 Nm 115 lb in
    Oil Pan Baffle Bolts
    12 Nm 106 lb in
    Oil Pan Bolt (M8)
    25 Nm 18 lb ft
    Oil Pan Closeout Cover Bolt – Left Side
    12 Nm 106 lb in
    Oil Pan Closeout Cover Bolt – Right Side
    12 Nm 106 lb in
    Oil Pan Cover Bolts
    12 Nm 106 lb in
    Oil Pan Drain Plug
    25 Nm 18 lb ft
    Oil Pan M8 Bolts – Oil Pan-to-Engine Block and Oil Pan-to-Front Cover
    25 Nm 18 lb ft
    Oil Pan M6 Bolts – Oil Pan-to-Rear Cover
    12 Nm 106 lb in
    Oil Pressure Sensor
    20 Nm 15 lb ft
    Oil Pump-to-Engine Block Bolts
    25 Nm 18 lb ft
    Oil Pump Cover Bolts
    12 Nm 106 lb in
    Oil Pump Relief Valve Plug
    12 Nm 106 lb in
    Oil Pump Screen-to-Oil Pump Bolt
    12 Nm 106 lb in
    Oil Pump Screen Nut
    25 Nm 18 lb ft
    Oxygen Sensor
    42 Nm 31 lb ft
    Positive Battery Cable Fitting
    15 Nm 11 lb ft
    Positive Crankcase Ventilation (PCV) System Strap Nut – at Right Front Engine Coolant Air Bleed Pipe Stud
    12 Nm 106 lb in
    Powertrain Control Module (PCM) Connector Bolt
    8 Nm 71 lb in
    Power steering Gear Bolt
    85 Nm 63 lb ft
    Power Steering Pump Bracket Bolt
    50 Nm 37 lb ft
    Secondary Air Injection (AIR) Pipe Bolt
    20 Nm 15 lb ft
    Secondary Air Injection (AIR) Switch Valve Bracket Bolt
    20 Nm 15 lb ft
    Secondary Air Injection (AIR) Switch Valve Bracket Nut
    12 Nm 106 lb in
    Shock Absorber Bolt
    65 Nm 48 lb ft
    Spark Plug (All Subsequent Installations)
    15 Nm 11 lb ft
    Spark Plug (New Cylinder head)
    20 Nm 15 lb ft
    Stabilizer Bar Bracket Bolt/Stud
    55 Nm 41 lb ft
    Throttle Body Bolts
    12 Nm 106 lb in
    Torque Converter Bolt
    63 Nm 47 lb ft
    Transmission Bolt (Automatic Transmission)
    95 Nm 70 lb ft
    Transmission Bolt (Manual Transmission)
    50 Nm 37 lb ft
    Transmission Cover Bolt
    12 Nm 106 lb in
    Transmission Fill Tube Bolt
    50 Nm 37 lb ft
    Transmission Oil Cooler Line Fitting
    27 Nm 20 lb ft
    Transmission Support Bolt
    57 Nm 42 lb ft
    Upper Control Arm Nut
    53 Nm 39 lb ft
    Valve Lifter Guide Bolt
    12 Nm 106 lb in
    Valve Rocker Arm Bolt
    30 Nm 22 lb ft
    Valve Rocker Arm Cover Bolt
    12 Nm 106 lb in
    Water Inlet Housing Bolts
    15 Nm 11 lb ft
    Water pump Bolts – First Pass
    15 Nm 11 lb ft
    Water Pump Bolts – Final Pass
    30 Nm 22 lb ft
    Water Pump Cover Bolts
    15 Nm 11 lb ft
    For OEM applications and all these figures are per GM.
    2002 Z06 - Electron Blue Metallic - D1 @ 14psi - E85 - Forged - Kooks LT's - Kooks exhaust - RPS clutch - RPM trans - 100# ID injectors - Holley 12-1400 Dominator pump **701 RWHP 687 RWTQ** || 2014 Silverado Z71 5.3: A6 Blue Topaz - OEM || 2002 Z28: M6 NBM **sold**
    Good info!
    This has always been my goto for torque specs: http://ls1howto.com/index.php?category=1
      yuuuup thats helpful alright! sticky this in a tech section
        Good info!
        Always a good source! This info came right from GM's service info. So it's always a go to for OEM specs.
          torquing the oil filter on some cars SUCKS
            is hand tight good enough? never understood why they need an impact to get some of these filters off lol hand tight then a 1/8th of turn after that...done!
              Factory filters suck to get off. Everything is put on dry. Mopar factory ones usually say factory installed on them for warranty reason.
                You beat me to it earlier lol. I was about to do the same thing
                Go BIG or go HOME!
                  Stuck-ed! Thanks for posting.
