Thought I'd be helpful
Fastener Tightening Specifications Application
Specification
Metric / English
A/C Belt Tensioner Bolt
25 Nm 18 lb ft
A/C Compressor and Condenser Hose Bolt (at Accumulator)
16 Nm 12 lb ft
A/C Compressor and Condenser Hose Bolt (at Compressor)
33 Nm 24 lb ft
A/C Compressor Bolts
50 Nm 37 lb ft
A/C Compressor Bracket Bolts
50 Nm 37 lb ft
Accelerator Control Cable Bracket Nut
10 Nm 89 lb in
Air Conditioning (A/C) Belt Idler Pulley Bolt
50 Nm 37 lb ft
Air Injection Reaction (AIR) Pipe-to-Exhaust Manifold Bolts
20 Nm 15 lb ft
Battery Positive Cable Nut (at Generator Output Stud)
22 Nm 16 lb ft
Brake Pipe Fitting
15 Nm 11 lb ft
Camshaft Position (CMP) Sensor Bolt
25 Nm 18 lb ft
Camshaft Retainer Bolt
25 Nm 18 lb ft
Camshaft Sprocket Bolt
35 Nm 26 lb ft
Catalytic Converter Nut
25 Nm 18 lb ft
Clutch Pressure Plate Bolt (In Sequence and Evenly Over 3 Increments)
70 Nm 52 lb ft
Connecting Rod Bolts – First Pass
20 Nm 15 lb ft
Connecting Rod Bolts – Final Pass
85 degrees
Coolant Temperature Gauge Sensor
20 Nm 15 lb ft
Crankshaft Balancer Bolt – Installation Pass-to Ensure the Balancer is Completely Installed
330 Nm 240 lb ft
Crankshaft Balancer Bolt – First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes
50 Nm 37 lb ft
Crankshaft Balancer Bolt – Final Pass
140 degrees
Crankshaft Bearing Cap Bolts – Inner Bolts – First Pass in Sequence
20 Nm 15 lb ft
Crankshaft Bearing Cap Bolts – Inner Bolts – Final Pass in Sequence
80 degrees
Crankshaft Bearing Cap Side Bolts
25 Nm 18 lb ft
Crankshaft Bearing Cap Studs – Outer Studs – First Pass in Sequence
20 Nm 15 lb ft
Crankshaft Bearing Cap Studs – Outer Studs – Final Pass in Sequence
51 degrees
Crankshaft Oil Deflector Nuts
25 Nm 18 lb ft
Crankshaft Position (CKP) Sensor Bolt
25 Nm 18 lb ft
Crossmember Bolt (Lower)
145 Nm 107 lb ft
Crossmember Bolt (Upper)
125 Nm 92 lb ft
Cylinder Head Bolts (First Pass all M11 Bolts in Sequence)
30 Nm 22 lb ft
Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence)
90 degrees
Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head)
90 degrees
Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence)
50 degrees
Cylinder Head Bolts (M8 Inner Bolts in Sequence)
30 Nm 22 lb ft
Cylinder Head Coolant Plug
20 Nm 15 lb ft
Drive Belt Idler Pulley Bolt
50 Nm 37 lb ft
Drive Belt Tensioner Bolt
50 Nm 37 lb ft
End Link Nut
23 Nm 17 lb ft
Engine Block Coolant Drain Plugs
60 Nm 44 lb ft
Engine Block Heater
40 Nm 30 lb ft
Engine Block Oil Gallery Plugs
60 Nm 44 lb ft
Engine Coolant Air Bleed Pipe Bolts and Studs
12 Nm 106 lb in
Engine Flywheel Bolt (First Pass)
20 Nm 15 lb ft
Engine Flywheel Bolt (Second Pass)
50 Nm 37 lb ft
Engine Flywheel Bolt (Final Pass)
100 Nm 74 lb ft
Engine Front Cover Bolts
25 Nm 18 lb ft
Engine mount Bolt
50 Nm 37 lb ft
Engine Mount Bracket Bolt
58 Nm 43 lb ft
Engine Mount Heat Shield Nut
10 Nm 89 lb in
Engine mount Stud
50 Nm 37 lb ft
Engine Mount Through Bolt
95 Nm 70 lb ft
Engine Mount Through Bolt Nut
10 Nm 89 lb in
Engine Oil Filter
30 Nm 22 lb ft
Engine Rear Cover Bolts
30 Nm 22 lb ft
Engine Service Lift Bracket M10 Bolts
50 Nm 37 lb ft
Engine Service Lift Bracket M8 Bolt
25 Nm 18 lb ft
Engine Valley Cover Bolt
25 Nm 18 lb ft
Engine Wire Harness Clip Bolt
50 Nm 37 lb ft
Engine Wire Harness Clip Bolt (at Automatic Transmission)
2.5 Nm 22 lb in
Engine Wire Harness Ground Bolt
50 Nm 37 lb ft
Engine Wire Harness Ground Bolt (at Frame Rail)
12 Nm 106 lb in
Engine Wire Harness Ground Bolt (Left Side of Engine block)
30 Nm 22 lb ft
Exhaust Manifold Bolts – First Pass
15 Nm 11 lb ft
Exhaust Manifold Bolts – Final Pass
20 Nm 15 lb ft
Exhaust Manifold Heat Shield Bolts
9 Nm 80 lb in
Exhaust Manifold Pipe Nut
35 Nm 26 lb ft
Front Fuel Pipe Heat Shield Nut
5 Nm 44 lb in
Fuel Injection Fuel Rail Bolts
10 Nm 89 lb in
Fuseblock Stud Nut
14 Nm 10 lb ft
Generator Bolt
50 Nm 37 lb ft
Generator Rear Bracket Bolt
25 Nm 18 lb ft
Ground Terminal Bolt
6 Nm 53 lb in
Ignition Coil Bolt
12 Nm 106 lb in
Ignition Coil-to-Bracket Bolts
12 Nm 106 lb in
Ignition Coil Bracket-to-Valve Rocker Arm Cover Studs
12 Nm 106 lb in
Intake Manifold Bolts (First Pass in Sequence)
5 Nm 44 lb in
Intake Manifold Bolts (Final Pass in Sequence)
10 Nm 89 lb in
Intermediate Steering Shaft Bolt
47 Nm 35 lb ft
Knock Sensors
20 Nm 15 lb ft
Negative Battery Cable Lead Bolt
32 Nm 24 lb ft
Oil Filter
30 Nm 22 lb ft
Oil Filter Fitting
55 Nm 40 lb ft
Oil Level Indicator Tube Bolt
25 Nm 18 lb ft
Oil Level Sensor
13 Nm 115 lb in
Oil Pan Baffle Bolts
12 Nm 106 lb in
Oil Pan Bolt (M8)
25 Nm 18 lb ft
Oil Pan Closeout Cover Bolt – Left Side
12 Nm 106 lb in
Oil Pan Closeout Cover Bolt – Right Side
12 Nm 106 lb in
Oil Pan Cover Bolts
12 Nm 106 lb in
Oil Pan Drain Plug
25 Nm 18 lb ft
Oil Pan M8 Bolts – Oil Pan-to-Engine Block and Oil Pan-to-Front Cover
25 Nm 18 lb ft
Oil Pan M6 Bolts – Oil Pan-to-Rear Cover
12 Nm 106 lb in
Oil Pressure Sensor
20 Nm 15 lb ft
Oil Pump-to-Engine Block Bolts
25 Nm 18 lb ft
Oil Pump Cover Bolts
12 Nm 106 lb in
Oil Pump Relief Valve Plug
12 Nm 106 lb in
Oil Pump Screen-to-Oil Pump Bolt
12 Nm 106 lb in
Oil Pump Screen Nut
25 Nm 18 lb ft
Oxygen Sensor
42 Nm 31 lb ft
Positive Battery Cable Fitting
15 Nm 11 lb ft
Positive Crankcase Ventilation (PCV) System Strap Nut – at Right Front Engine Coolant Air Bleed Pipe Stud
12 Nm 106 lb in
Powertrain Control Module (PCM) Connector Bolt
8 Nm 71 lb in
Power steering Gear Bolt
85 Nm 63 lb ft
Power Steering Pump Bracket Bolt
50 Nm 37 lb ft
Secondary Air Injection (AIR) Pipe Bolt
20 Nm 15 lb ft
Secondary Air Injection (AIR) Switch Valve Bracket Bolt
20 Nm 15 lb ft
Secondary Air Injection (AIR) Switch Valve Bracket Nut
12 Nm 106 lb in
Shock Absorber Bolt
65 Nm 48 lb ft
Spark Plug (All Subsequent Installations)
15 Nm 11 lb ft
Spark Plug (New Cylinder head)
20 Nm 15 lb ft
Stabilizer Bar Bracket Bolt/Stud
55 Nm 41 lb ft
Throttle Body Bolts
12 Nm 106 lb in
Torque Converter Bolt
63 Nm 47 lb ft
Transmission Bolt (Automatic Transmission)
95 Nm 70 lb ft
Transmission Bolt (Manual Transmission)
50 Nm 37 lb ft
Transmission Cover Bolt
12 Nm 106 lb in
Transmission Fill Tube Bolt
50 Nm 37 lb ft
Transmission Oil Cooler Line Fitting
27 Nm 20 lb ft
Transmission Support Bolt
57 Nm 42 lb ft
Upper Control Arm Nut
53 Nm 39 lb ft
Valve Lifter Guide Bolt
12 Nm 106 lb in
Valve Rocker Arm Bolt
30 Nm 22 lb ft
Valve Rocker Arm Cover Bolt
12 Nm 106 lb in
Water Inlet Housing Bolts
15 Nm 11 lb ft
Water pump Bolts – First Pass
15 Nm 11 lb ft
Water Pump Bolts – Final Pass
30 Nm 22 lb ft
Water Pump Cover Bolts
15 Nm 11 lb ft
For OEM applications and all these figures are per GM.
Specification
Metric / English
25 Nm 18 lb ft
16 Nm 12 lb ft
33 Nm 24 lb ft
50 Nm 37 lb ft
50 Nm 37 lb ft
10 Nm 89 lb in
50 Nm 37 lb ft
20 Nm 15 lb ft
22 Nm 16 lb ft
Brake Pipe Fitting
15 Nm 11 lb ft
25 Nm 18 lb ft
25 Nm 18 lb ft
35 Nm 26 lb ft
25 Nm 18 lb ft
70 Nm 52 lb ft
20 Nm 15 lb ft
85 degrees
20 Nm 15 lb ft
330 Nm 240 lb ft
50 Nm 37 lb ft
140 degrees
20 Nm 15 lb ft
80 degrees
25 Nm 18 lb ft
20 Nm 15 lb ft
51 degrees
25 Nm 18 lb ft
25 Nm 18 lb ft
145 Nm 107 lb ft
125 Nm 92 lb ft
30 Nm 22 lb ft
90 degrees
90 degrees
50 degrees
30 Nm 22 lb ft
20 Nm 15 lb ft
50 Nm 37 lb ft
50 Nm 37 lb ft
End Link Nut
23 Nm 17 lb ft
60 Nm 44 lb ft
Engine Block Heater
40 Nm 30 lb ft
60 Nm 44 lb ft
12 Nm 106 lb in
20 Nm 15 lb ft
50 Nm 37 lb ft
100 Nm 74 lb ft
25 Nm 18 lb ft
Engine mount Bolt
50 Nm 37 lb ft
58 Nm 43 lb ft
10 Nm 89 lb in
Engine mount Stud
50 Nm 37 lb ft
95 Nm 70 lb ft
10 Nm 89 lb in
Engine Oil Filter
30 Nm 22 lb ft
30 Nm 22 lb ft
50 Nm 37 lb ft
25 Nm 18 lb ft
25 Nm 18 lb ft
50 Nm 37 lb ft
2.5 Nm 22 lb in
50 Nm 37 lb ft
12 Nm 106 lb in
30 Nm 22 lb ft
15 Nm 11 lb ft
20 Nm 15 lb ft
9 Nm 80 lb in
35 Nm 26 lb ft
5 Nm 44 lb in
10 Nm 89 lb in
Fuseblock Stud Nut
14 Nm 10 lb ft
Generator Bolt
50 Nm 37 lb ft
25 Nm 18 lb ft
6 Nm 53 lb in
Ignition Coil Bolt
12 Nm 106 lb in
12 Nm 106 lb in
12 Nm 106 lb in
5 Nm 44 lb in
10 Nm 89 lb in
47 Nm 35 lb ft
Knock Sensors
20 Nm 15 lb ft
32 Nm 24 lb ft
Oil Filter
30 Nm 22 lb ft
Oil Filter Fitting
55 Nm 40 lb ft
25 Nm 18 lb ft
Oil Level Sensor
13 Nm 115 lb in
12 Nm 106 lb in
Oil Pan Bolt (M8)
25 Nm 18 lb ft
12 Nm 106 lb in
12 Nm 106 lb in
Oil Pan Cover Bolts
12 Nm 106 lb in
Oil Pan Drain Plug
25 Nm 18 lb ft
25 Nm 18 lb ft
12 Nm 106 lb in
Oil Pressure Sensor
20 Nm 15 lb ft
25 Nm 18 lb ft
12 Nm 106 lb in
12 Nm 106 lb in
12 Nm 106 lb in
Oil Pump Screen Nut
25 Nm 18 lb ft
Oxygen Sensor
42 Nm 31 lb ft
15 Nm 11 lb ft
12 Nm 106 lb in
8 Nm 71 lb in
85 Nm 63 lb ft
50 Nm 37 lb ft
20 Nm 15 lb ft
20 Nm 15 lb ft
12 Nm 106 lb in
Shock Absorber Bolt
65 Nm 48 lb ft
15 Nm 11 lb ft
20 Nm 15 lb ft
55 Nm 41 lb ft
Throttle Body Bolts
12 Nm 106 lb in
63 Nm 47 lb ft
95 Nm 70 lb ft
50 Nm 37 lb ft
12 Nm 106 lb in
50 Nm 37 lb ft
27 Nm 20 lb ft
57 Nm 42 lb ft
53 Nm 39 lb ft
12 Nm 106 lb in
30 Nm 22 lb ft
12 Nm 106 lb in
15 Nm 11 lb ft
15 Nm 11 lb ft
30 Nm 22 lb ft
15 Nm 11 lb ft
Thanks for posting.
